94 GMC - tach and locks
cordoba360
Member - Posts: 7
Posted: January 03, 2004 at 7:56 PM / IP Logged
hello there... im a long time reader and first time poster, here is what i have ...
1994 GMC extended cab 2wd 305 wA\T, and will be installing a Audiovox APS-786. I have a couple of questions,
1. Can i take my tach singnal from behind the dash where the TACH is , i mean the wire that leads to the littel motor that drive the tach , or do i have to run the wire throught the firewall and grab the WHITE wire at the ignition coil, or the ECM by chance?
2.I have positive door locks, do i use the 5 wire setup exactly as shown in the Door locks section of the forum? seems like i do, but i want to make sure before i start blowing motors
draasch
Gold - Posts: 2,172
Posted: January 03, 2004 at 8:28 PM / IP Logged
Make:   GMC
Model: Sierra/Fullsize P/U
Year:    1992-94
This Database Was Last Updated On:    6/9/2003
Index #: 663
Alarm
Constant 12 volts RED AND RED IGNITION SWITCH HARNESS
Ignition 12 volts PINK IGNITION SWITCH HARNESS
Starter PURPLE OR YELLOW IGNITION SWITCH HARNESS
Dome Light WHITE (-) PIN SWITCH OR AT COURTESY LIGHT
Trunk Pin Switch N/A
Parking Lamp BROWN (+) AT LIGHT SWITCH
Power Lock L BLUE BEHIND OR BELOW #203
Power Unlock BLACK/ WHITE DRIVER SPEAKER
#203- See Reversal Rest At Ground Door Lock Diagram.
Remote Start
Tach Signal WHITE AT DISTRIBUTOR OR COIL *
Ignition #2 ORANGE IGNITION SWITCH HARNESS (HEAT-A/C)
Ignition #3 N/A
Accessory BROWN IGNITION SWITCH HARNESS (RADIO/WIPER)
Neutral Safety ORANGE / BLACK (-) AT SWITCH ON STEERING COLUMN **
Brake Light WHITE (+) AT SWITCH ON BRAKE PEDAL BRACKET
Reverse Light LIGHT GREEN (+) AT SWITCH ON STEERING COLUMN
Rear Window Defrost
* Can Also Be Found In A Single Wire Test Connector Which Is Taped To Harness Near Distributor. ** If Equipped With Electronic Automatic Transmission, Neutral Safety Switch May Be Mounted But Not Wired. Two Bare Terminals Will Be Present. Ground One Terminal And Take Neutral Safety Wire From Remote Start To Other.
yes u can try that wire....however you have to run a wire through the firewall for the siren, you might just want to run a second wire for the tach at that time and hook it up under the hood................
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
sroth140
Silver - Posts: 513
Posted: January 04, 2004 at 1:12 AM / IP Logged
i dont think you can grab the tach at the cluster.  i think on those trucks the cluster has a set of contacts that plug into the harness, and it unplugs when you pull the cluster out.  on the 2000+ GM trucks you can pull the cluster out and use the only white wire in that harness for the tach.  go to the ecm behind the glove box for your tach wire,  its pretty easy to go to.
for locks, 5 wire (type C) on the two door models, and its a positive trigger (type A) on the four door and keyless entry models.  lock is light blue, unlock is BLACK/ red
i just did one of these trucks last weekend and i reached up to the door boot from way down in the drivers kick panel and pulled a few harness down and out a little into the cab.  i found the 5wi lock/unlock in a harness and made my connections there.  it was easier than doing it between the body and the door in that rubber boot.
cordoba360
Member - Posts: 7
Posted: January 04, 2004 at 10:06 AM / IP Logged
thanks for the help , i thought i didnt think i needed to reverse the polarity like mentioned above for these locks as the audiovox can go either way
so i will be doing it this way https://www.the12volt.com/doorlocks/page3.asp#5w
because i found this think https://www.the12volt.com/installbay/forum_posts.asp?tid=22554&KW=93+chev+lock
and was a little confused, thanks alot guys your great, some of the other automotive forums ive been to are a little bit on the wacky side, everything else seems straight forward
Thanks Again !
cordoba360
Member - Posts: 7
Posted: January 10, 2004 at 10:33 PM / IP Logged
Just to piggy back on my original question, obviously the truck doesnt have a trunk.
So what do i do with the trunk wire from the module since i wont be using it , do i just ground that wire, or tape it off like the rest of them. Im just curious since i wont be using the trunk release button ?
daniel2002p
Silver - Posts: 524
Posted: January 10, 2004 at 11:00 PM / IP Logged
Just tape it off
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
