2001 Ford Windstar door lock pulse?forRS
mdff17
Member - Posts: 6
Posted: January 05, 2004 at 10:48 PM / IP Logged
   I am installing a Crimestopper RS901 remote start in the van.  I got it all hooked up but I can't find a neg pulse to activate the starter off the factory remotes.  My diagram says LT blue/orange at FEM i checked it no pulse.  I checked that wire at the door lock switch and it has the pulse there only when you hit the button on the door not with the remotes.  If I take the activation wire and ground it the van starts and runs fine but I need to figure out how to give it a pulse through the remotes.  Thanks...Mike
draasch
Gold - Posts: 2,172
Posted: January 06, 2004 at 12:40 PM / IP Logged
see if this will help you..........
program the RS to start on a double pulse from the door lock....
Power Unlock L GREEN/ YELLOW ELECTRONIC MODULE ***
*** F.E.M.Is Behind Driver's Dash Panel. #201 - See Negative Pulse Door Lock Diagram.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
mdff17
Member - Posts: 6
Posted: January 06, 2004 at 2:02 PM / IP Logged
 I only have the option of a single pulse or 3 pulses on the RS unit.  you say the LGREEN/ YELLOW wire will give me a double pulse may be I will have to hit the lock button twice that will give it one extra pulse but should still work.  This wire is in the FEM can I probe it at the FEM plug to check for the pulse?  Is there a wire like this for the lock side so I can lock the doors when it starts.  Thanks..Mike
draasch
Gold - Posts: 2,172
Posted: January 06, 2004 at 3:48 PM / IP Logged
i posted the wrong color.....
Power Lock L BLUE/ORANGE
20 PIN CONNECTOR AT FRONT ELECTRONIC MODULE ***
it will give you one pulse for each time you push the lock button on the transmitter.....
Good Luck
David
Ace Security
813-376-9778
Tampa
