2001 Honda Accord remote start
bw05
Posted: January 06, 2004 at 12:44 PM / IP Logged
I 'm needing a wiring diagram for a 2001 Honda Accord so I can install a remote starter that I just purchased. Can anyone help me with this?
RufNUSD
Copper - Posts: 184
Posted: January 06, 2004 at 12:49 PM / IP Logged
12volts white   +   ignition harness
Starter BLACK/ white   +   ignition harness
Notes: If doing starter kill, must interrupt the wire between the keyswitch and the fusebox, not between the fusebox and the starter, to keep the check engine light from coming on.
Second Starter N/A
Ignition BLACK / YELLOW   +   ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory yellow   +   ignition harness
Second Accessory WHITE/ black   +   ignition harness
Keysense
Power Lock BLACK/ blue   -   passenger side fuse box
Notes: in a green 20 pin connector.
Use BLACK/ white for lock and GREEN/ red for unlock on LX models without factory security. These wires are located in a two pin gray connector by the front of the drivers side fuse box.
Power Unlock orange   -   passenger side fuse box
Lock Motor WHITE/ red      driver side fuse box
Unlock Motor        driver side fuse box
Notes: yellow on the EX and lt. GREEN/ red on the LX
Parking Lights+ RED / black      driver side fuse box
Parking Lights- RED / yellow      steering column
Notes: Only available on the EX model.
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light GREEN/ black   +   driver side fuse box
Door Trigger BLACK/ white   -   passenger side fuse box
Notes: In a green 4 pin connector.
Dome Supervision use door trigger
Trunk/Hatch Pin orange   -   drivers kick panel
Notes: Above the hood release in a gray 18 pin connector. On the DX & LX models, also found in a 2 pin connector behind the drivers fuse box.
Hood Pin yellow/red or yellow   -   hood pin switch or
Notes: On the EX models it is in a green plug next to the passenger side fuse box. On the LX models it is at the keyless/security unit, if equipped, which is attached to the driver side underdash panel.
Trunk/Hatch Release WHITE/ red   +   drivers kick panel
Power Sliding Door
Factory Alarm Arm
Notes: Arms and disarms with the door locks on the EX models. The LX models arm only with the factory transmitter.
Factory Alarm Disarm
Disarm No Unlock blue   -
Notes: On the EX the wire is located at the drivers power window switch, on the LX the wire is at the keyless/security unit which is attached to the drivers underdash panel.
Tachometer blue      tach test connector
Notes: The tach test connector is located behind the battery on the 4 cylinder, and on a bracket attached to the drivers side strut tower on the 6 cylinder motor. The tach test connector is a white 2 pin connector, and may be covered by a black rubber boot.
Wait to start
Brake Wire WHITE/ black   +   brake pedal switch
Horn Trigger lt. GREEN/ blue   -   steering column
Immobilizer Bypass Module: Required: Yes Type: Transponder Part #: 555H or 555U
Someone pass me that bottle.
bw05
Posted: January 06, 2004 at 1:03 PM / IP Logged
Thank You very much. This car does have the factory security and I also did purchase the bypass module. I purchased it all in one package for 12volt direct. Thanks again
