Amplifier wiring
Gtgt
Posted: January 08, 2004 at 7:27 AM / IP Logged
Hi,
I am about to install a 4 channel amp to drive my front and rear speakers.
My head unit has pre outs for the front and rear channels so no problems so far!
My concern is what happens to the head units internal amp. There seems to be no way of switching it off. Does the fact that I will have RCA leads connected tell it not to power up? I believe that if you run an amp with no speakers connected it will be damaged.
Does somebody have an answer for me please.
gt
DYohn
Platinum - Posts: 10,741
Posted: January 08, 2004 at 8:21 AM / IP Logged
Your head unit amp will not be damaged.  I suggest the only thing you need to do, if there are speaker wires connected to the internal amp, is insulate them so they cannot short out to each other or to the car (use some electricial tape or wire nuts.)
Cheers.
Gtgt
Posted: January 08, 2004 at 8:24 AM / IP Logged
Thanks DYohn,
I'll just pull the speakers plug from my head unit which should do the job then.
gt
cavyman
Copper - Posts: 88
Posted: January 08, 2004 at 9:15 AM / IP Logged
You have a different plugs for your power wires and your speaker wires?
1 plus 1 equals 2
Gtgt
Posted: January 08, 2004 at 9:20 AM / IP Logged
Sure do. I have two plugs on 2 leads from the back of the unit. One is the powergroup, the other for the front and rear speakers.
gt
frazierk
Member - Posts: 8
Posted: January 08, 2004 at 7:40 PM / IP Logged
Either disconnect the plug for the internal amp on the radio, or tape the leads up real good so they don't short to anything. Not hooking them up will not damage the unit.
kjf
Sunday, February 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
