GM OEM Denali Nav in a Yukon XL SLT?
agtkgv
Posted: January 08, 2004 at 3:57 PM / IP Logged
Has anyone tried putting the OEM DVD Nav system in a Yukon or Suburban/Tahoe with XM/On Star. I am thinking it should be like the Jeep Just install the nav antenna and plug and play??? Help, will make the difference wheter I get a Denali or SLT.
sparkie
Platinum - Posts: 2,061
Posted: January 08, 2004 at 7:56 PM / IP Logged
The factory navigation systems only work in the Denali's or Escalades. It won't work in any other fullsize GM truck.
sparky
rodneyt74
Posted: January 08, 2004 at 9:41 PM / IP Logged
Yeah.. if want factory nav unit then need to buy caddy or denali.  The dealer can't even install a nav unit in a current 04 denali thats sitting on lot and doesn't have nav unit in it.  They have to be order in the vehicle for some reason.  Guess there is alot of wiring difference between the two.
rodneyt74
Posted: January 08, 2004 at 10:00 PM / IP Logged
Well...  did a little research just here in the forum.. and seems there is one guy in forum that has already put a nav unit in a gm truck.  Said all he had to do is install the factory gps antenna and then have the dealer reprogram it for the vin number...  don't know if it will work with 04 vehicles but might try emailing this guy and talking to him.  probably has more info then most do.  here is a link to the forum messages https://www.the12volt.com/installbay/forum_posts.asp?tid=21862&PN=4
Hope this helps...
sparkie
Posted: January 09, 2004 at 2:34 PM / IP Logged
The factory Nav radio requires an amplifier that works on the data bus system and this is only available in the 04 Denali's and Escalades.
sparky
richs
Member - Posts: 37
Posted: January 18, 2004 at 2:37 PM / IP Logged
If it can be installed in your particular vehicle, the GM dealer because they have to program the head/nav unit for your vehicle and also program your vehicle (BCM) for the unit. You will have to check with your GM dealer to see if it is possible.
Best Regards,
Rich
