Alarm/Neon Interface Question? Help ?
enmity
Member - Posts: 6
Posted: January 08, 2004 at 8:57 PM / IP Logged
Can Someone Please Help Me Out?!!?!?!!?!?!?
I am trying to install a Streetglow LED Underbody Kit and am having trouble hooking up the alarm interface. What you are able to do with the system is to hook up a connection where when the alarm system is armed a ground is supplied to the LED Control Box and the center bank is to blink once a second. However I am having difficulty getting this to work correctly. I have posted the diagram of how i have it wired below can anyone help me out here?
Streetglow LED Underbody Kit - ANDLED100
http://www.streetglow.com/products/instructions/anled100.pdf
Alarm - Clifford Matrix RS3
http://www.directed.com/guides/manuals/ig/clifford/N909554.pdf
Alarm/Neon Interface Question? Help ? -- posted image.
Any help would be greatly apreciated
Thanks ahead of time,
Jesse
sst_sys@hotmail.com
Coomer
Copper - Posts: 103
Posted: January 08, 2004 at 9:54 PM / IP Logged
From what I'm getting out of your diagrams, it looks like you need to hook up terminal 30 of your relay to your battery(with a fuse of course.) That's assuming that "LED alarm interface" is the blue circle on the L.E.D. underbody controller.
auex
Platinum - Posts: 5,041
Posted: January 08, 2004 at 10:08 PM / IP Logged
Hold on, the diagram specifically says ground. Try just running a ground to the blue wire and see if it works. Also, you are putting it in alarm mode right?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Teken
Gold - Posts: 1,492
Posted: January 08, 2004 at 10:23 PM / IP Logged
Ignore my last post, I am too tired... Totally misread that manual. Zzzzzzzzzzzzzz Alarm/Neon Interface Question? Help ? -- posted image.
Regards
EVIL Teken . . .
enmity
Member - Posts: 6
Posted: January 08, 2004 at 10:52 PM / IP Logged
I made sure that the alarm mode works by just connecting the blue wire (alarm turn-on FIG. 2) to a ground and that works. But that is not a solution just a way to make it work. I need that blue wire to get a ground signal when the alarm is active. I also dont understand what the point to putting a fuse on a ground wire would do
thanks
jesse
sst_sys@hotmail.com
enmity
Member - Posts: 6
Posted: January 08, 2004 at 10:57 PM / IP Logged
Also just so everyone know the diagrams i made to hook it up but that is not working. for the manufactures diagrams they are at the above links. hopefully with some help we can get this figured out
thanks again
Jesse
sst_sys@hotmail.com
Teken
Gold - Posts: 1,492
You would simply take the starter kill relays *ground while armed* from the alarm, to activate the ground which you require to turn on the LEDs.
Regards
EVIL Teken . . .
enmity
Member - Posts: 6
Posted: January 08, 2004 at 11:24 PM / IP Logged
I tried that and every time i do that i blows the fuse to the battery
Jesse
sst_sys@hotmail.com
enmity
Member - Posts: 6
Posted: January 08, 2004 at 11:25 PM / IP Logged
the vechile that i am putting this on is a 98' Ford Expedition if that make any differance
Jesse
sst_sys@hotmail.com
Teken
Gold - Posts: 1,492
Posted: January 08, 2004 at 11:43 PM / IP Logged
A relay and a diode must be placed in the circuit.
