2002 Acura RSX sunroof
Platinum - Posts: 12,488
Posted: August 03, 2002 at 7:50 AM / IP Logged
  • SUN RF OPEN----------grn/yel -----------| - |----------------relays above driver kick
  • SUN RF CLOSE---------  grn/blk --------------  | -  |----------------relays above driver kick
Posted: August 05, 2002 at 6:55 AM / IP Logged
If you don't have a DMM or light tester... I would not go any farther as far as installation goes. All the wire color codes that we supply are from reference material ONLY and can not be trusted until tested properly. The sunroof open/close wirse are actually (-) activation wires not 12 volt positive. You must add negative ground to it to activate the OEM relay.I do not have the suroof wire colors for the two car listed, but you can easily grab them at the switch.
