Remote Start with existing factory alarm
meh66
Copper - Posts: 266
Posted: January 12, 2004 at 7:16 PM / IP Logged
Just a general question,
  What should you do if a car has a factory alarm with keyless entry? The owner only wants to add a remote start. I think it does not make sense to have two remotes for one car. Can you have the remote start remote control the factory alarm? Should you just install a new alarm with remote start and disable the factory alarm. Thanks.
MEH66
"Car Performance and Mobile Electronic Enthusiats"
lspker
Silver - Posts: 503
Posted: January 12, 2004 at 7:46 PM / IP Logged
You can use an auxilarily output off the factory alarm, such as power trunk, to fire the starter, but you lose the trunk function.  Some remote starters, such as the Crimesopper RS-900 can be triggered by locking the doors three times quickly with the factory remote.  Draw back is the range is limited to that of the factory unit.   You can replace the factory remote with the after market, but you'll do more work.
meh66
Copper - Posts: 266
Posted: January 13, 2004 at 10:07 AM / IP Logged
Thanks for the input, but I have another question. Where would I hook it up? Will i have to hook up the rs trigger to power door lock wires?
MEH66
defective
Silver - Posts: 642
Posted: January 13, 2004 at 10:37 AM / IP Logged
yup....you connect the input trigger of the RS (one with the factory feature) to the lock wire of the vehicle, when the doorlock wire of the vehicle gets three pulses in a row, the RS will activate.  If you need the color and location of the factory RS wire, tell us your year and vehicle. I could even get you the factory keyless wire colors.
Wednesday, January 14, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
