Headlight Wigwag
RufNUSD
Copper - Posts: 184
Posted: January 15, 2004 at 7:09 PM / IP Logged
Does anyone have the diagram for this? Ive seen one that involves the siren output and the FL output on the alarm. Im looking for the one that involves a flasher and a couple of relays as Id like it hooked up on a switch independent of the alarm. Thanks!!!
Someone pass me that bottle.
RufNUSD
Copper - Posts: 184
Posted: January 21, 2004 at 1:07 AM / IP Logged
I got it figured out. Involves 2 relays, 3 pole flasher and a rheostat for speed adustment.
carlosmaymat
Posted: January 21, 2004 at 10:09 PM / IP Logged
when you get it working  post diagram to see how it works
civic02
qz2vw0
Member - Posts: 6
Posted: January 23, 2004 at 2:11 PM / IP Logged
I saw a wig-wag unit at Galls.  I presume it would be www.galls.com - they do police and ambulance equipment.
This space for rent
pfitz
Copper - Posts: 53
Posted: January 29, 2004 at 8:27 AM / IP Logged
We beat this question to death a few weeks ago, there are several diagrams and even more ideas posted.  Your best option is to get a factory made flasher, unless you have or can get the parts real cheap, because it will cost you more in the long run.
pfitz
Copper - Posts: 53
Posted: January 29, 2004 at 8:32 AM / IP Logged
PS:  Galls is probably the most expensive of all the emergency lighting suppliers.  Try Code 3or4? and Whelen(sp), just do a general search and a bunch should pop-up.
Thursday, March 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
