Can an alarm LED drive a relay?
Derekc
Member - Posts: 34
Posted: January 17, 2004 at 3:12 AM / IP Logged
Can an alarm LED drive a relay to a neon light?
Would it have enough current to drive? Or flash too fast to drive?
My red LED is just too weak. I want to hookup a neon light under the dash.
dc
daniel2002p
Silver - Posts: 524
Posted: January 17, 2004 at 9:22 AM / IP Logged
On most alarm it cannot because they are only 2 or 3 volt systems, but you can measure the coltage coming out of the alalrm, and if it 12v, then you can hook up a relay.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
clearman
Member - Posts: 46
Posted: January 17, 2004 at 10:33 AM / IP Logged
I know radio shack has some 5 volt relays with a pull in voltage of about 4 volts. Many cmputer supply places have very low voltage relays. Depending on the voltage, you might be able to use one of these but use it to trip the 12 volt relay rather than turn on the light. The 12 volt relay will then turn on the light. The small relay will handle enough amperage to trip the bigger relay.
Derekc
Member - Posts: 34
Posted: January 17, 2004 at 10:41 AM / IP Logged
Totally forgot about the low voltage use of the LED.
So glad to have you guys. I was planning to mess with it. Now I know I shouldn't.
dc
xetmes
Silver - Posts: 586
Posted: January 17, 2004 at 12:15 PM / IP Logged
you can use a transistor... search these boards its been asked a few times...
Wednesday, August 13, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
