04 Grand Cherokee
allchromed01r1
Member - Posts: 36
Posted: January 17, 2004 at 9:01 AM / IP Logged
Anyone know where and the color of the databus wire for the door lock module in this vehicle????? help asap please and thank you.
chris
boomer_106
Silver - Posts: 710
Posted: January 17, 2004 at 10:29 AM / IP Logged
Jeep
Grand Cherokee
2003-2004
Remote Starter Wiring Colors and Notes
Function
Vehicle Color
Location
Start:
Yellow (+)
Ignition switch harness*
Ignition #1:
Dk.Blue (+)
Ignition #2:
N/A
Ignition #3:
N/A
Accessory:
RED / Black (+)
Brake Light:
PURPLE / Tan(+) or WHITE/ Tan (+)
Drivers kick panel
Tach Signal:
See Note**
See Note**
Parking Lights:
Yellow (-)
Headlight switch
Headlights:
N/A
OEM Alarm Disarm:
Lt.GREEN/ Orange (-)
Drivers door lock switch
OEM Alarm Arm:
N/A
Diesel Glow Plug:
N/A
Clutch Bypass Wire:
N/A
Notes:
* This vehicle may be equipped with Chrysler's Smart Key Transponder Theft System only if the ignition key is gray. Use Universal Alarm Bypass Module part # 2x402 where X can by any number. ** On the 4.0L use any of the tan wires at the coil pack.
Jeep
Grand Cherokee
2003-2004
Alarm and Keyless Entry Wiring Colors and Notes
Function
Vehicle Color
Location
Constant +12 Volts:
Red & Pink/Black (+)
Starter Kill:
Yellow (+)
Ignition +12 Volts:
Dk.Blue (+)
Dome Lights/Superv:
See Note
OEM Horn:
Gray/Orange (-)
Steering column harness
Power Lock:
See Note
Power Unlock:
See Note
Trunk Release:
N/A
Alarm Input Wire:
See Note
Notes:
**Use vehicle specific doorlock module part # 23544. ***The driver door trigger is Tan/Red at the driver door switch. The driver's rear door is Tan/Orange and the passenger's rear door is Tan / YELLOW at the BCM. The passenger's door is Tan/Red at the passenger's door switch.
NowYaKnow
Gold - Posts: 1,217
Posted: January 17, 2004 at 10:42 AM / IP Logged
EDIT: Haven't done one of these in a while but I'm pretty sure it should be yellow/purple in pin 2 @ the diagnostic connector. It is located underdash near the fusebox. That small black fusebox cover also has a cutout where the diagnostic connector sits so look for that.
Saturday, November 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
