1991 towncar alarm
Teken
Gold - Posts: 1,492
Posted: January 18, 2004 at 2:16 PM / IP Logged
prdjr165 wrote:
The factory dis-arm wire is ORANGE / black!The car still doe's not start and stay running,I give up!
I'm sorry you didnt read what I wrote. I indicated that there IS a ORANGE / BLACK wire from the RS-900 which is used to send a (-) ground pulse to the OEM wire.
So as you are able to disable the OEM alarm, while RSing the unit upon activation.
Regards
EVIL Teken . . .
prdjr165
Copper - Posts: 293
Posted: January 18, 2004 at 4:05 PM / IP Logged
Regards
EVIL Teken . . .
prdjr165
Copper - Posts: 293
Posted: January 18, 2004 at 4:08 PM / IP Logged
TEKEN..I read what you wrote!you should read what I wrote!I hooked up thr or/blk wire to the cars oem disarm wire(dk grn/prpl)still no good!
Teken
Gold - Posts: 1,492
Posted: January 18, 2004 at 5:30 PM / IP Logged
Are you 100% sure this is the correct OEM disarm wire?
chriswallace187
Gold - Posts: 1,661
Posted: January 18, 2004 at 8:43 PM / IP Logged
Prdjr, I'd suggest not worrying about the fact. disarm. The only thing that a factory antitheft would do on that car would be to interrupt the starter and honk the horn when the ignition was turned on. It sounds to me like there's a problem with the tach or voltage sense (I had this '97 Crown Vic in today that would only stay running for 3 minutes in tach mode - strangest thing I've seen in a while). Have you tried remote starting with engine checking off altogether, or with a low sensitivity? I've never done a crimestopper, so those may not be options, but it's definitely not going to be a prob. with the factory alarm not disarming.
prdjr165
Copper - Posts: 293
Posted: January 18, 2004 at 9:37 PM / IP Logged
I am 100% sure because like I said before the anti-theft light will go out when I neg. pulse this wire.In the owners manual it states that the factory theft system monitors the ignition switch for 3 minutes after the theft system is armed.I'm going to try and get the car back next weekend and mess with it again,I think I should just start from scratch.
prdjr165
Copper - Posts: 293
Posted: February 07, 2004 at 7:02 PM / IP Logged
I finally found the problem..The remote start unit is a new version so the tach programing was changed,I was doing it the old way which was not working.Once I programed it the new way it workes great!!
Page of 3
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
