Volvo S40 Remote starter wiring diagram
kidlark
Posted: January 18, 2004 at 4:56 PM / IP Logged
I am looking for a remote starter wiring diagram for a 2000 Volvo S40. Can anyone help me out?
My signature
boomer_106
Silver - Posts: 710
Posted: January 18, 2004 at 11:36 PM / IP Logged
Yep here it is kidlark.
Volvo
S40
2000-2002
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
GREEN
IGNITION SWITCH HARNESS *
Ignition  #1:
BLUE/PINK
Ignition #2:
BLUE/BLACK
Ignition  #3:
N/A
Accessory:
BLUE
Brake  Light:
PINK/BLACK (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
GREEN OR GRAY
AT COILS ON TOP OF MOTOR UNDER COVER
Parking Lights:
BLUE / YELLOW (+)
AT CEM MODULE BEHIND LEFT SIDE OF DASH
Headlights:
GRAY/RED (-)
AT SWITCH
OEM Alarm  Disarm:
DISARMS WITH UNLOCK
OEM Alarm  Arm:
ARMS WITH LOCK
Diesel  Glow Plug:
N/A
Clutch  Bypass Wire:
N/A
Notes:
 * This vehicle is equipped with a transponder immobilizer system. See Installation Note #144 - Bypassing Transponder Theft Systems. ** There Are Four Separate Wires For Each Door, Use Each And Diode Isolate With Bands Of Diodes Facing Away From The Alarm/Remote Start Module. Colors Are Green (Driver's), GREEN/ Orange (Pass Front), GREEN/ Red (Left Rear), GREEN / WHITE (Right Rear). All Triggers Are Negative.
Volvo
S40
2000-2002
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
WHITE
Starter  Kill:
GREEN
Ignition  +12 Volts:
BLUE/PINK
Dome  Lights/Superv:
MULTIPLE WIRES SEE NOTE
AT ANTI-THEFT MODULE LOCATED IN CENTER CONSOLE
OEM Horn:
GREEN (HIGH CURRENT NEGATIVE)
STEERING COLUMN HARNESS ***
Power  Lock:
PINK/BLACK (-)
AT ANTI-THEFT MODULE LOCATED IN CENTER CONSOLE ****
Power  Unlock:
BROWN (-)
Trunk  Release:
BROWN / BLACK (-)
Alarm  Input Wire:
Notes:
*** This Wire Directly Feeds The Horn, So A Relay Must Be Used To Provide A Strong Enough Ground Signal. DO NOT CONNECT DIRECTLY TO REMOTE START WITHOUT USING A RELAY! **** See Installation Note #201 - Negative Trigger Door Lock Diagram. Unlock Requires Double Pulse, First Pulse Disarms The Alarm, Second Pulse Unlocks The Doors. See also Note #231 ofr double pulse information if your unit does not have a double pulse option.
rz5000r
Posted: February 02, 2004 at 9:37 AM / IP Logged
Does anyone have the wiring diagram for a 2004 Volvo S40? Or is it the same as the 2002? Thanks.
