451M in 02 Nissan Altima
su_root
Member - Posts: 13
Posted: January 20, 2004 at 1:38 AM / IP Logged
hi, and thanks for reading. i have an 02 altima and i had bought the clifford rs, at the moment an installer installed the remote start of the system but he also gave me the 451M so i could control the door locks using the same remote and i could eliminate the factory remote.  However im looking through the install instruction that the 451m came with and its a bit confusing ! from what i understand i need to find the master lock switch which should be in driver door panel, then follow the wires to the kickpanel to install the 451M. after that i have no idea what to do. It talks about type A,B,C,D,E systems, and i honestly dont know what i have. Id really like to do this myself..i just dont want to damage anything. Any help will be greatly appreciated.  i know where my alarm main module is..does that 3 wire white plug it came with plug into the alarn directly?? thank you
rgds
draasch
Gold - Posts: 2,172
Posted: January 20, 2004 at 7:51 AM / IP Logged
Power Lock PINK AT #201
Power Unlock BROWN BCM * SEE TECH
* BCM Located Behind Fuse Box. #201- See Negative Pulse Door Lock Diagram.
* There Are Two Types Of Door Lock Systems Found On This Vehicle If You Do Not See The Wires Listed For Lock And Unlock You Will Need To Go Into The Drivers Door And Find The Key Cylinder Wires Listed As PINK/BLUE Arm And Lock, WHITE/ BLUE Disarm And Unlock.Test From Key Cylinder.#201.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
su_root
Member - Posts: 13
Posted: January 20, 2004 at 8:56 AM / IP Logged
thanks for the info drasch...theres only one thing.
what exactly do i do when i find those cables. where do i connect them. do i connect them to the white 3wire plug that is on the 451M? if so, how? theres 6 other wires coming out of the 451M what do i do with those? i really am a noob, so i apologize for not undersatnding, thanks
rgds
su_root
Member - Posts: 13
Posted: January 20, 2004 at 9:13 AM / IP Logged
also, it came with a pack of resistors, do i need to put those anywhere..i found this picture searching through the forums..i just wanted to know if it applies to my vehicle as well....
451M in 02 Nissan Altima - Last Post -- posted image.
if it does apply to me, why do the green and blue connect right before they get to back of fuse box?? also do i have to use the resistors shown here? maybe i just dont undersatnd the diagram..also this picture doesnt show the small 3wire white plug coming out the 451M..where does that go? ive read if i have a DEI alarm it just plugs into my alarm. is this true??
please dont leave out any small details that you would normally think are trivial because id really like to make this work correctly. thanks for reading..
draasch
Gold - Posts: 2,172
Posted: January 20, 2004 at 9:17 AM / IP Logged
i dont use that line...do you have a site for the parts that you have?? we should be able to get you up and running..
Good Luck
David
Ace Security
813-376-9778
Tampa
su_root
Member - Posts: 13
Posted: January 20, 2004 at 10:25 AM / IP Logged
what do u mean by a site for the parts i have?
i use the clifford matrix rs, the remote start system with keyless entry. the alarm is already installed in the car and it works fine. i was given the 451M to add myself, and id really like to have it connected so i can get rid of my factory remote.
what line dont you use?
thanks
Tuesday, May 21, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
