2002 Chevy Impala remote start
Irvin Cruz
Member - Posts: 11
Posted: January 20, 2004 at 7:01 PM / IP Logged
Need help. Installing Valet 552T Remote Start. Here's the info.
Ground OK
Constant/ All fuses Good
Tach, got it (white at ignition coil) PURPLE / Wht of RS
Programmed Tach wire by starting car and pressing Valet button until LED constant..
Starter Wire-Yellow, connected to Purple
Constant 12V- Red, connected to Red
Ignition One- Pink, connected to Pink
Ignition 2- Green, coonected to Pink/Wht
Acc-Orange, connected to Orange
Brake Wire- White, connected to brown wire
Testing before installing 555L module with KEY IN the Ignition, Remote Start lights up, then dies...Have installed previously same car, always tested connections with key in the ignition before 555L. Switched brains and remotes, still same problem. ANY ideas......
kwhitelaw
Posted: January 20, 2004 at 10:26 PM / IP Logged
Did you power up the brown wire as an accessory? If powered as an ignition, the car will not run.
prdjr165
Copper - Posts: 293
Posted: January 21, 2004 at 3:46 AM / IP Logged
If the car doesn't crank at all it's usually the hood pin wire or the brake wire is grounded.If the car cranks but don't start it's a ignition wire not being fed or the bypass module not set up correctly.
Monday, January 26, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
