Silencer 6908A
jetski0602
Posted: January 22, 2004 at 7:23 PM / IP Logged
Could someone please tell me where the heck i can find some install manual for a Silencer 6908A. I got it on Ebay. big mistake i guess.. I have no idea which wires are which. also can someone tell me where i can get a wiring diagram for my car so i can install this thing as well.
thnx
bmf1000d
Silver - Posts: 345
Posted: January 23, 2004 at 1:06 AM / IP Logged
what kind of car you have i can get you that too as for the wiring on the alarm does it look like this?
http://www.magnadyne.com/index.cfm?MasterAction=Item&InvMasID=5279&Web_Catid=300
"Big" Mike
Double Take
Fremont, Ne
remember to check all your wires with a dmm not a test light!!
i take no responsibilty whatsoever for the vailidty of the info nor consequences thereof
jetski0602
Posted: January 23, 2004 at 7:32 AM / IP Logged
yeh that's the one i got. it came with all this as well, which can all be found on that site you sent me.
6908A model alarm, 5901 H1 kit,  H-EX2-2,  ALA 95    and 5905PR
all these seem to just be the parts to a full kit. and the ALA 95 is the shock sensor. All i really want is the keyless entry though.
my car is a 1998 Nissan Sentra GXE
thnx
bmf1000d
Silver - Posts: 345
Posted: January 25, 2004 at 10:01 PM / IP Logged
I dont have the wirng schmatic for a maganadyne but maybe someone else does on the forum.
Anyone that sells magnadyne or carbine please post a wiring schematic for us. Thnaks
"Big" Mike
Double Take
Fremont, Ne
draasch
Gold - Posts: 2,172
Posted: January 25, 2004 at 10:09 PM / IP Logged
Make:   Nissan
Model: Sentra
Year:    1998
This Database Was Last Updated On:    6/9/2003
Index #: 7275
Alarm
Constant 12 volts GREEN IGNITION SWITCH HARNESS
Ignition 12 volts BLACK/ RED IGNITION SWITCH HARNESS
Starter BLACK / YELLOW IGNITION SWITCH HARNESS
Dome Light RED / WHITE (-) 20 PIN CONNECTOR IN DR. KICK PANEL *
Trunk Pin Switch RED (-) AT LIGHT IN TRUNK **
Parking Lamp RED / BLUE (+) AT HEADLIGHT SWITCH
Power Lock GRAY 16 PIN CONNECTOR #201
Power Unlock PURPLE IN DRIVER KICK PANEL
* RED / WHITE (-) Dome Light Wire Also Located At "Smart Entry Control Timer" Behind Driver Dash Or At Any Pin Switch. ** With OEM Alarm: RED (-) Trunk Wire Also Located At "SMart Entry Control Timer" Behind Driver Dash. #201- See Negative Pulse Door Lock Diagram
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
