94 Chyrsler LSH factory disarm wire
eloc187
Posted: January 26, 2004 at 5:47 PM / IP Logged
I'm trying to find out where to find a wiring diagram that shows the factory alarm system for my 94 LSH. The car has a factory keyless/alarm system on it and I have already instaled an aftermarket alarm. As of now when I arm the car with the aftermarket remote it arms the factory system and I have to use both the aftermarket and factory remote to dissarm. I have found the box I beleive is the factory alarm on top of the dash on the pass. side and I have tryed every combination of wire to turn off the system but no luck. Also I don't know if this means anything or not but when I bought this car the owner told me that if I ever lost the factory remote I would be in trouble cause the factroy alarm always arms itself when the doors are locked and it wont shut off without the remote. I thought most factory alarms would deactivate if the key was used in either the drivers or pass door? This doesn't work on my car. Thanks for any help.
Eloc187
bmf1000d
Silver - Posts: 345
Posted: January 26, 2004 at 5:53 PM / IP Logged
the factory disarm wire for your car is in the drivers kick and is Light GREEN/ orange and needs to have a + pulse sent to it
"Big" Mike
Double Take
Fremont, Ne
remember to check all your wires with a dmm not a test light!!
i take no responsibilty whatsoever for the vailidty of the info nor consequences thereof
