2003 Toyota MR2 Spyder
01jettawolfy
Posted: January 28, 2004 at 3:22 PM / IP Logged
Alarm diagram anyone, please. Thanks in advance.
boomer_106
Silver - Posts: 710
Posted: January 29, 2004 at 10:29 PM / IP Logged
Toyota
MR Spyder
2003
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
Red (+)
Ignition switch harness
Ignition  #1:
BLACK / YELLOW (+)
Ignition switch harness*
Ignition #2:
RED / White (+)
Ignition  #3:
N/A
Accessory:
Pink/Blue (+)
Brake  Light:
GREEN / WHITE (+)
Brake pedal switch
Tach  Signal:
White (AC)
Drivers running board
Parking Lights:
Green (+)
Drivers kick panel
Headlights:
N/A
OEM Alarm  Disarm:
N/A
OEM Alarm  Arm:
N/A
Diesel  Glow Plug:
N/A
Clutch  Bypass Wire:
N/A
Notes:
 *This vehicle is equipped with a Transponder Anti-Theft security system. Use Universal Alarm Bypass Module part # 2x402 where X can be any number.
Toyota
MR Spyder
2003
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
WHITE/ Red & WHITE/ Blue (+)
Starter  Kill:
Red (+)
Ignition  +12 Volts:
BLACK / YELLOW (+)
Dome  Lights/Superv:
N/A
OEM Horn:
WHITE/ Red (-)
Steering column harness
Power  Lock:
Blue/White (-)
Drivers kick panel **
Power  Unlock:
Blue / YELLOW (-)
Drivers kick panel
Trunk  Release:
N/A
Alarm  Input Wire:
N/A
Notes:
**See Note #201 Negative Trigger Door Locks.
