95 Mitsubushi Eclipse Tach Wire
polhamus
Posted: April 07, 2002 at 1:08 AM / IP Logged
Somebody help me please!  I'm looking for the Tach wire to install my auto starter, but have found no luck so far.  If anyone could be of assistance I would surely appreciate it!
Thanks,
D Polhamus
D Polhamus
chrispcwiz
Member - Posts: 11
Posted: April 07, 2002 at 8:06 AM / IP Logged
hi,
 the tach wire for that car is white and is located ate the pcm or instrument cluster.
The PCM is located on the drivers side of the engine compartment or behind the center of the dash depending on motor.
good luck
  chris
Platinum - Posts: 12,488
Posted: April 07, 2002 at 10:01 AM / IP Logged
If you still can not find the tach wire, you can use the injector wire from any of the injectors ( use the uncommon colored ones )
Monday, April 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
