setting up amps
dfiddy
Copper - Posts: 162
Posted: February 01, 2004 at 8:43 PM / IP Logged
I do a lot of stereo's and don't know exactly what to listen for when setting up amps. I mostly do alpine products, with some rockford. Is there any good sites out there any of you know of? I would like to know what exactly everything on an amp does and just understand what everything does to set them up properly. Any help would be great.
bberman1
Gold - Posts: 2,314
Posted: February 01, 2004 at 8:49 PM / IP Logged
Teamrf
Gold - Posts: 1,031
Posted: February 01, 2004 at 11:53 PM / IP Logged
If you look  in the manual that comes with amps it usually tells you what each control is for. I usually just cut the amp down, turn the radio up about 3/4 of the way, and turn it up just below distortion. Some cars you may have to go a little lower because they may have an older electrical system and may pick up engine whine.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
