98 honda accord ABS
Signal
Member - Posts: 7
Posted: February 02, 2004 at 11:35 PM / IP Logged
I have a 98 accord EX V6 that i just recently put in a remote stater. When i start the car with the remote the ABS light comes on.Anyone know what is causing it to come on or how i could solve this problem???
bmf1000d
Silver - Posts: 345
Posted: February 02, 2004 at 11:42 PM / IP Logged
Does it stay on when the RS is shut off?
"Big" Mike
Double Take
Fremont, Ne
remember to check all your wires with a dmm not a test light!!
i take no responsibilty whatsoever for the vailidty of the info nor consequences thereof
JWorm
Platinum - Posts: 2,208
Posted: February 03, 2004 at 8:58 PM / IP Logged
12volts      white       +       ignition harness
Starter      BLACK/ white       +       ignition harness
Ignition      BLACK / YELLOW       +       ignition harness
Accessory      yellow       +       ignition harness
Second Accessory      WHITE/ black       +       ignition harness
I did a 98 or 99 recently and I hooked up one of the accessory wires as an ignition. The ABS light then came on when remote started. Fortunately, the remote starters we use have a jumper I could just move to switch that output to operate as an accessory wire and everything worked fine. Most remote starters come with outputs for two ignitions and one accessory, so I'm gonna guess you might have run into the same problem as me. What remote start system are you using?
Signal
Member - Posts: 7
Posted: February 04, 2004 at 8:07 PM / IP Logged
I am using a prestige 996 pager RS. I figure i prob got the wrong wires for ACC and IGN. the ABS only comes on sometimes when remote started.
jgold47
Copper - Posts: 69
Posted: February 06, 2004 at 6:25 PM / IP Logged
could be low on brake fluid, or if you hooked up a neutral saftey wire to the ebrake it could be backfeeding into the light..
Saturday, April 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
