Alarm install -01'GMC 1500HD ?
justice29
Member - Posts: 7
Posted: February 09, 2004 at 12:19 PM / IP Logged
I am in the process of purchasing an Autopage 850 alarm/remote start for my 2001 GMC Sierra 1500HD pickup that came with the factory keyless entry/security system.  Are there any special circumstances that I should be aware of?   I have read about some Ford vehicles triggering the alarm after a certain amount of time because of a power shutdown.
Is there anything like that relating to the GMC P/U's?
Any help is greatly appreciated.
John
Moderator - Posts: 12,488
Posted: February 09, 2004 at 1:27 PM / IP Logged
The only thing you have to do with this truck for the door triggers is to diode isolate them from each other and also you will need a bypas module for the remote start for the truck to bypass the Passlock II system it has. Use the PLDATA for easiest bypass module available.
soultinter
Copper - Posts: 170
Posted: February 09, 2004 at 3:51 PM / IP Logged
you may encounter the RAP system that keeps your radio on after shutdown.
sparkie
Platinum - Posts: 2,061
Posted: February 09, 2004 at 5:33 PM / IP Logged
The factory alarm can be re-armed by pulsing the door lock wire ( + light blue at BCM under steering column) and the driver's doorpin wire ( - tan at the BCM) at the same time. This will also shut off the radio's reatained power circuit.
sparky
