speaker wiring
bobdigital
Member - Posts: 7
Posted: February 10, 2004 at 10:23 AM / IP Logged
i drive an 86 toyota camry, and im having problems with my 6 by 9's in the rear and the 4 and a halfs in the front, there seems to be a loose connection cause when i hit a bump, the sometimes shut off and just my subs will play,  anybody know were i can find that loose connection that goes to all my speakers?
thanks
bob
thapimpfromchi
Silver - Posts: 616
Posted: February 10, 2004 at 10:59 AM / IP Logged
check the harness on the back of ur radio, might be loose. I had a similar problem with my head unit once.
1990 Honda Civic HB:
Clarion DXZ545MP H.U.
2- 6.5" Power Acoustik interiors
Diamond Audio 600.1 amp
Diamond Audio 15" M6MKII
Pyramid PB881X 4 CH. Amp
spl_enterprise
Copper - Posts: 62
Posted: February 10, 2004 at 4:41 PM / IP Logged
if it isnt at the back of you head unit use the fader and balance and single out a speaker at a time until you find the problem.
Pete - SPL Enterprise Inc.
forbidden
Platinum - Posts: 5,354
Posted: February 10, 2004 at 4:46 PM / IP Logged
That is the correct response, all it takes is one speaker wire to go to ground to send the entire amp into protection. This mmay be at the speaker in a door or the actual wire iteslf between point a and point b. Disconnect all speakers, hook up one speaker at a time, go for a bumpy drive. No problems, hook up the next speaker. Find the problem.
bobdigital
Member - Posts: 7
Posted: February 11, 2004 at 1:45 PM / IP Logged
thanks all, i got it working!!!!
bob
