Door Lock Help
92coupe
Posted: February 21, 2004 at 5:26 AM / IP Logged
I have an 88 stang, and I just got my alarm installed......they didnt hook up the power door lock part, and I have power door locks.......can I just run a relay from the alarm's out put + and - through a wire that goes to  the door lock button? Any help would be awesome......thanks....
sparkie
Platinum - Posts: 2,061
Posted: February 21, 2004 at 4:52 PM / IP Logged
I believe your door lock circuit type is a 5 wire polarity reversal rest at ground. The lock wire is pink / YELLOW and the unlock wire is pinl/light green. They can be found in either kick panel. You will need two relays to wire the door locks up to your alarm.
sparky
