1997 toyota camry
Welcome Guest :)
skiflyer45
Member -
Posted: February 21, 2004 at 1:00 PM / IP Logged
Hi,
can anyone provide me with a wiring diagram for a 97 toyota camry. I need it for a keyless entry/ALARM install.
Thanks in advance
---Alex---
boomer_106
Silver -
Posted: February 23, 2004 at 8:29 PM / IP Logged
Here ya go Alex
Remote Starter Wiring Colors and Notes |
Function | | Vehicle Color | Location |
Start: | | RED | IGNITION SWITCH HARNESS ** |
Ignition #1: | | BLACK/ RED | IGNITION SWITCH HARNESS |
Ignition #2: | | BLACK / YELLOW | IGNITION SWITCH HARNESS |
Ignition #3: | | N/A | |
Accessory: | | BLUE/RED | IGNITION SWITCH HARNESS |
Brake Light: | | GREEN / WHITE | AT SWITCH ABOVE BRAKE PEDAL |
Tach Signal: | | BLACK ORANGE | AT ECM OR IGNITOR * |
Parking Lights: | | GREEN (+) | AT # PIN WHITE CONN. AT FUSE PANEL |
Headlights: | | RED / YELLOW (-) | AT HEADLIGHT SWITCH |
OEM Alarm Disarm: | | RED / GREEN (-) | # PIN CONN IN DRIVER'S KICK PANEL |
OEM Alarm Arm: | | | |
Diesel Glow Plug: | | | |
Clutch Bypass Wire: | | | |
Notes: | | * ECM Is Located Behind The Glove Box. ** Beginning in 1998, this vehicle is equipped with a transponder type of theft system. See Installation Note #144 - Bypassing Transponder Theft Systems. |
Alarm and Keyless Entry Wiring Colors and Notes |
Constant +12 Volts: | | WHITE/ RED & WHITE | IGNITION SWITCH HARNESS |
Starter Kill: | | RED | IGNITION SWITCH HARNESS ** |
Ignition +12 Volts: | | BLACK/ RED | IGNITION SWITCH HARNESS |
Dome Lights/Superv: | | RED / WHITE (-) | 7 PIN WHITE CONN. ABOVE FUSE PANEL |
OEM Horn: | | GREEN/ BLACK (-) | IN STEERING COLUMN HARNESS |
Power Lock: | | LIGHT GREEN (-) | # PIN CONN IN DRIVER'S KICK PANEL *** |
Power Unlock: | | DARK GREEN (-) | # PIN CONN IN DRIVER'S KICK PANEL *** |
Trunk Release: | | N/A | |
Alarm Input Wire: | | RED / WHITE (-) | 7 PIN WHITE CONN. ABOVE FUSE PANEL |
Notes: | | ** Child Safety Wire is BLUE/RED (-) in same connector as door locks. See Note # 209 - Child Safety Door Lock Diagram. |
Saturday, May 18, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
