remote start on C280 mercedes benz
SSteve
Member - Posts: 20
Posted: February 24, 2004 at 5:39 PM / IP Logged
I installed a RF 750 LCD (AUTO PAGE) REMOTE STARTER
Everything worked good, (yeah right)
this is the problem: if i plug the door locks  it won't start the car, then when I unplug the the alarm works great!
any help? thank you!
ssteve
Steve
draasch
Gold - Posts: 2,172
Posted: February 24, 2004 at 5:41 PM / IP Logged
what year is the car?????
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
SSteve
Member - Posts: 20
Posted: February 24, 2004 at 6:08 PM / IP Logged
I'm  sorry the year is 1995
Steve
draasch
Gold - Posts: 2,172
Posted: February 24, 2004 at 6:17 PM / IP Logged
Make:   Mercedes Benz
Model: C Class
Year:    1995
this what i have:
Power Lock BLACK DRIVER KICK #201
Power Unlock BLUE PANEL
#201- See Negative Pulse Door Lock Diagram.
Good Luck
David
Ace Security
813-376-9778
Tampa
Rmeyer
Member - Posts: 13
Posted: February 24, 2004 at 10:47 PM / IP Logged
the reason the car will not start is the mercedes has a factory starter interrupt built in when the doors lock, does the remote start lock the doors when you try to start the vehicle, if so try programing that feature out and the car will probably start, if not try to catch the PURPLE / white close to the firewall were the wire from the inside of the car go under the hood and that will bypass the factory starter kill.
Rmeyer
Member - Posts: 13
Posted: February 24, 2004 at 10:48 PM / IP Logged
also try to program out ignition locks.
SSteve
Member - Posts: 20
Posted: February 25, 2004 at 5:45 PM / IP Logged
THank you very f**kin much Rmeyer!
GOD BLESS YOU and give you even  more intellegency.
Steve
