2001 Kia spectra wiring diagram
northballer
Copper - Posts: 57
Posted: February 29, 2004 at 1:02 AM / IP Logged
I need a wiring diagram for a 2001 kia spectra gsx. Thanks
cbag1
Copper - Posts: 59
Posted: February 29, 2004 at 3:09 AM / IP Logged
12volts WHITE/ black and white  +  ignition harness
Starter red  +  ignition harness
Second Starter N/A
Ignition yellow  +  ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory blue  +  ignition harness
Second Accessory green  +  ignition harness
Keysense lt. GREEN/ red  +  ignition harness
Power Lock add actuator    in driver door
Power Unlock same
Lock Motor N/A
Unlock Motor N/A
Parking Lights+ pink (L), pink/blue (R)  +  driver kick, harness to rear
Parking Lights- RED / yellow  -  headlight switch
Hazards same as turn signals
Turn Signal(L) GREEN/ YELLOW  +  steering column
Turn Signal(R) GREEN / WHITE  +  steering column
Reverse Light RED / yellow or blue/black  +  driver kick, harness to rear
Door Trigger lt. GREEN/ red  -  driver kick panel
Dome Supervision use door trigger
Trunk/Hatch Pin blk/lt. grn or GREEN/ YELLOW  -  light in trunk
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm N/A
Factory Alarm Disarm N/A
Disarm No Unlock N/A
Tachometer yellow/white  ac  data link conn,L strut tower
Wait to start N/A
Brake Wire RED / black  +  brake pedal switch
Parking Brake PURPLE / white  -  parking brake sw or cluster
Horn Trigger blue/red  -  steering column
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
2001 Kia spectra wiring diagram -- posted image.
Immobilizer Bypass Module:Required: NoType: N/APart #: N/A
Notes: N/A
Friday, September 12, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
