1995 F350 Ground when off wire
kencasino
Posted: March 01, 2004 at 11:13 AM / IP Logged
I need to find a wire that is ground when truck is shut off and floats when engine is running for an alarm display (without alarm system)
can't seem to find it in diagrams from chilton or on this forum - I thought I heard somewhere that it was in the ignition switch harness.
I dont want to install another switch for this.
cbag1
Copper - Posts: 59
Posted: March 01, 2004 at 12:01 PM / IP Logged
use radioshack led flasher that do same what you need.
kencasino
Posted: March 01, 2004 at 12:28 PM / IP Logged
already bought the $40 led flash bar
Ravendarat
Platinum - Posts: 2,806
Posted: March 01, 2004 at 4:34 PM / IP Logged
Just use the ignition wire behind the deck or off the stearing column. I have done it plenty of times, no problms.
