Omega AL-100C+Toy Camry02 keyless entry
maxima96
Posted: March 02, 2004 at 1:08 PM / IP Logged
I have bought this OMEGA AL-100C (crimeguard) alarm, to integrate with the 2002 Toyota Camry factory keyless entry module.  Upon finished, i can alarm and disarm the alarm with the Toyota factory remote.  The alarm can function properly.  However, I can also disarm and arm the system using the "door lock" switch inside the car.  Is it possible to hook up this alarm such that only the remote can activate the alarm, not the door lock?  thanks in advance.
I used 4 wires in relate to alarm interface:
Camry door lock at switch (light Green wire) ----> Omega alarm lock - (white wire) / with diode
Camry door unlock at switch (GREEN/ Red wire) ----> Omega alarm unlock - (brown wire) / with diode
Camry door lock at motor (Blue/Red wire) ----> Omega alarm lock + (pink wire) /without diode
Camry door unlock at motor (Blue/black wire) ----> Omega alarm unlock + (Gray wire) /without diode
eespro
Member - Posts: 11
Posted: March 02, 2004 at 2:20 PM / IP Logged
just discoonnect the White wire from the Green wire.
maxima96
Posted: March 03, 2004 at 12:57 AM / IP Logged
thanks.  i will give it a try.
desh187
Copper - Posts: 310
Posted: March 04, 2004 at 1:47 AM / IP Logged
ground white wire
pink wire is motor lock-blue/red 11 pin gray conn dkp
gray wire is driver unlock -blue/black as above.
brown wire is all unlock -blue/black pass kick panel.
maxima96
Posted: March 05, 2004 at 2:44 AM / IP Logged
thank you eespro and desh187 for your valuable input.  Somehow, I got it to work.  I was trying out different methods.  Lastly, I still have the same configuration as I had previously.  The only thing I took out was that diode which connected the Omega White wire to the lightGreen Camry wire.  In addition, I unplug all of the connector, and reconnect all of the connectors once more.  The instruction from Omega AL100 says that the brown and white wires needs to be plug in first before connecting other wires such as power and ground.  I think that those wires were not properly initialized.   (those wires are for current sensing)  anyhow, its working now.  thanks for your time.
