dodge ram3500 1998
claude72
Member - Posts: 19
Posted: March 03, 2004 at 7:58 PM / IP Logged
hi,
i got the original speaker that i want to change for better ones,but i don't know how works those wire???
cuz,    it come with 2- 6x9'' at the door with cross-over on it, that have a bunch of wire, and 2- tweeter at  winshield sides, and in the back 2- 5.25'' 2-way  that have 2 pairs of wire stick to it???
     thanks
Claude B.
Metra Tech
Copper - Posts: 125
Posted: March 04, 2004 at 11:51 AM / IP Logged
It sounds to me like you have an Infinity amp in your vehicle. You cannot change the 6x9's in these vehicles with the Infinity sound system unless you install a new radio also. In these vehicles the radio powers the tweeters and rear speakers with low power and the amp that is strapped on the back of each 6x9 powers it with high power. I have never seen rear speakers with 2 pairs of wire going to them. but it should not pose a problem. Just use a speaker harness on it and you will be fine. Metra part# 72-4500.
claude72
Member - Posts: 19
Posted: March 04, 2004 at 8:48 PM / IP Logged
like you said, we see chrysler infinity on those speaker!!!
so if i understand i can only change the back speaker if i keep the radio?
what do you mean by speaker harness,it is for not sticking the 2 pairs of wire together? can i see it somewhere on the internet metra part 72-4500
   thanks
Claude B.
Metra Tech
Copper - Posts: 125
Posted: March 05, 2004 at 10:37 AM / IP Logged
Yes, if you change the speakers, you have to change the radio also. A speaker harness is a plug that will go into your factory plug and give you two wires out for your aftermarket speakers with a positive and negative terminal already on it. Unfortunately we do not have a picture on our website, but if you have a Best Buy near you, they most likely will have one for you to look at. It makes the job easy as there is no splicing and no guessing whats positive or negative.
claude72
Member - Posts: 19
Posted: March 05, 2004 at 12:14 PM / IP Logged
            dodge ram3500  1998 -- posted image.    thanks
Claude B.
Thursday, January 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
