2004 Toyota Tundra Door Locks
SSteve
Member - Posts: 20
Posted: March 06, 2004 at 3:52 PM / IP Logged
Any one please : what kind of door locks in 2004 toyota tundra ? colors? polarity?
Thank you
Steve
rudbwoy69camaro
Silver - Posts: 350
Posted: March 06, 2004 at 4:18 PM / IP Logged
Tundra..or double cab...
MAKE : TOYOTA | MODEL : TUNDRA | YEAR : 2004
12volts
  white (40A), WHITE/ red (30A)
  ignition harness
Starter  grn/blk (V6), blk/wht (V8)   +   ignition harness
Second Starter  N/A
Ignition  BLACK/ red   +   ignition harness
Second Ignition  BLACK / YELLOW   +   ignition harness
Third Ignition  N/A
Accessory  blue/red   +   ignition harness
Second Accessory  N/A
Keysense  pink/black   -   ignition harness or plug below fuses
Power Lock  WHITE/ green or GREEN/ black   -   driver kick or plug below fuses
Power Unlock  blue/red (double pulse)   -   driver kick or plug below fuses
Lock Motor  blue/white   5wi  driver kick, door harness
Unlock Motor  blue / YELLOW to BLACK / YELLOW   5wi  driver kick, door harness
Parking Lights+  green   +   driver kick, harness to rear
Parking Lights-  RED / black   -   headlight switch or plug below fuses
Hazards  GREEN/ red   -   turn signal flasher below fuse box
Turn Signal(L)  GREEN/ black   +   turn signal flasher below fuse box
Turn Signal(R)  GREEN/ YELLOW   +   turn signal flasher below fuse box
Reverse Light  RED / black   +   driver kick, harness to rear
Door Trigger  WHITE/ blue   -   driver kick, door harness
Dome Supervision  use door trigger wire
Trunk/Hatch Pin  N/A
Hood Pin  N/A
Trunk/Hatch Release  N/A
Power Sliding Door  N/A
Factory Alarm Arm  arms with lock
Factory Alarm Disarm  disarms with unlock
Disarm No Unlock  use key sense wire
Tachometer  black (V6), blue/white (V8)   ac   igniter (V6), ECM (V8)
Wait to start  N/A
Brake Wire  GREEN / WHITE   +   brake pedal switch
Parking Brake  RED / white   -   parking brake switch
Horn Trigger  GREEN/ red   -   column or plug below fuses
Memory Seat 1  N/A
Memory Seat 2  N/A
Memory Seat 3  N/A
Keysense note:
Using the status output wire from the remote start to trigger this wire will disarm the alarm without unlocking the doors.
Power Lock note:
Meter these wires while turning the key in the driver door key cylinder.
Power Unlock note:
Can also use the passenger key cylinder wire for unlock, which only requires a single pulse. It is RED / yellow or RED / white in the passenger kick or the plug below the fuses.
Tachometer note:
On the V6 models, the igniter is on the passenger fender.
On the V8 models, the ECM is behind the glove box. The tach wire is in the far right plug, pin 5.
MAKE : TOYOTA | MODEL : TUNDRA DOUBLE CAB | YEAR : 2004
12voltswht/blu (40A), wht/red (25A) + ignition harness
Starter  BLACK/ white   +   ignition harness
Second Starter  N/A
Third Ignition  N/A
Accessory  pink   +   ignition harness
Keysense  YELLOW /GREEN   -   ign harn or BECU, right plug, pin 22
Power Lock  see DirectFax document 1070
Power Unlock  see power lock notes
Lock Motor  blue/red   5wi  DKP or BECU, right plug, pin 1
Unlock Motor  RED / black   5wi  DKP or BECU, right plug, pin 14
Parking Lights-  green   -   switch or BECU, left plug, pin 14
Reverse Light  RED / black   +   driver kick, gray 8 pin plug, pin 2
Door Trigger  blue/black   -   ignition key cylinder illumination
Dome Supervision  comes on with unlock
Trunk/Hatch Pin  N/A
Hood Pin  blue/white   -   pin sw. or BECU, left plug, pin 5
Tachometer  WHITE/ blue   ac   ECM, right plug, pin 5
Wait to start  N/A
Parking Brake  lt. GREEN/ red   -   switch or BECU, right plug, pin 3
Horn Trigger  BLACK / YELLOW   -   column or BECU, right plug, pin 21
Memory Seat 1  N/A
Memory Seat 2  N/A
Memory Seat 3  N/A
Keysense note:
The BECU (Body ECU) is above the driver kick panel, towards the firewall.
Power Lock note:
The door lock wire colors are the same as those listed for the Sequoia.
Lock Motor note:
Unlock Motor note:
Parking Lights(-) note:
Door Trigger note:
Can also use individual door trigger wires at the BECU. The LF door is gray/red, middle plug, pin 15. The RF door is lt. GREEN/ black, right plug, pin 8. The LR door is RED / white, middle plug, pin 16. The RR door is RED / white, right plug, pin 4. Use all four wires and diode isolate each.
Hood Pin note:
Tachometer note:
The ECM (Engine Control Module) is behind the glove box.
Parking Brake note:
Horn Trigger note:
Tuesday, July 21, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
