right way of speaker wires
paquito71
Posted: August 15, 2002 at 12:37 AM / IP Logged
I  need one advise  i got 2  big amps.  i  am  rounding my  RCA cables of one side and my speaker wires whit the power line (4 G).  my question is  can my sistem get engine noise if  i round my sp. wires on the same way of my RCA. or
Moderator - Posts: 12,488
Posted: August 15, 2002 at 12:56 AM / IP Logged
Depends on the quality of RCA's your using. Most of the time the RCA's will not pick up the power signal from the speaker wire. Most RCA's are at least double shielded now so in the event that you have a ground loop... check your ground wire first to see if you have a solid ground bbefore you start moving the speaker wires awa from the RCA's.
Sunday, August 31, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
