need wiring diagram for 03 eclipse
Welcome Guest :)
jroson2
Member -
Posted: March 10, 2004 at 10:29 PM / IP Logged
i need a wiring diagram for a 2003 mitsu eclipse
please help!!!
Javelin3o4
Copper -
Posted: March 11, 2004 at 1:42 AM / IP Logged
| 12volts | WHITE/ red | + | ignition harness |
| Starter | BLACK/ red | + | ignition harness |
| Second Starter | N/A | | |
| Ignition | green | + | ignition harness |
| Second Ignition | N/A | | |
| Third Ignition | N/A | | |
| Accessory | blue/red | + | ignition harness |
| Second Accessory | blue/black | + | ignition harness |
| Keysense | blue/red | | ignition harness |
| Notes: This wire rests at ground, and goes to an open circuit when the key is inserted into the ignition cylinder. |
| Power Lock | purple | - | pin 33 at ETACS ECU |
| Notes: The ETACS ECU is attached to the back of the fuse box. |
| Power Unlock | lt. GREEN/ red | - | pin 34 at ETACS ECU |
| Lock Motor | lt. green | 5wi | pin 19, 28P plug below fuses |
| Unlock Motor | GREEN/ red | 5wi | pin 22 at ETACS ECU |
| Parking Lights+ | GREEN / WHITE | + | pin 2, 15P plug above fuses |
| Parking Lights- | N/A | | |
| Hazards | green | - | pin 55 at ETACS ECU |
| Turn Signal(L) | GREEN/ blue | + | pin 8, 15P plug above fuses |
| Turn Signal(R) | GREEN/ YELLOW | + | pin 13, 15P plug above fuses |
| Reverse Light | RED / blue | + | pin 9, 43 pin plug in DKP |
| Door Trigger | | - | |
| Notes: The driver door trigger is lt. green, pin 6, in a 15 pin plug above the fuses. The passenger door is lt. GREEN/ black in pin 65 at the ETACS ECU. Use both wires and diode isolate each.The ETACS ECU is attached to the back of the fuse box. |
| Dome Supervision | GREEN/ orange | - | pin 1,3 pin plug above fuses |
| Trunk/Hatch Pin | red | - | pin 62 or 37 at ETACS ECU |
| Notes: It is in pin 62 on the coupes, and in pin 37 on the convertible spyders.The ETACS ECU is attached to the back of the fuse box. |
| Hood Pin | GREEN/ red | - | pin 24 at ETACS ECU |
| Trunk/Hatch Release | GREEN / WHITE | 5wi | pin 32 at ETACS ECU |
| Power Sliding Door | N/A | | |
| Factory Alarm Arm | lt. GREEN/ black | - | pin 42 at ETACS ECU |
| Factory Alarm Disarm | orange | - | pin 25 at ETACS ECU |
| Disarm No Unlock | blue/red | - | pin 27 at ETACS ECU |
| Notes: Meter the wire while turning the key in the hatch/trunk key cylinder.The ETACS ECU is attached to the back of the fuse box. |
| Tachometer | white | ac | engine speed detect conn |
| Notes: The engine speed detection connector is a single pin connector in the fuse/realy box under the hood.Can also go to one of the ignition coils or the distributor assembly and use the BLACK/ blue or WHITE/ green wire. |
| Wait to start | N/A | | |
| Brake Wire | GREEN/ orange | + | brake pedal switch |
| Parking Brake | YELLOW /GREEN | - | parking brake switch |
| Horn Trigger | lt. GREEN/ black | - | pin 44 at ETACS ECU |
| Memory Seat 1 | N/A | | |
| Memory Seat 2 | N/A | | |
| Memory Seat 3 | N/A | | |
| Immobilizer Bypass Module: | Required: Yes | Type: Transponder | Part #: 555U |
| Notes: N/A |
Wednesday, November 26, 2025
• Copyright © 1999-2025 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
