Running an amp in an 04 Civic
nigelio
Posted: March 11, 2004 at 2:21 AM / IP Logged
I have an '04 civic 4 dr EX and I want run the amp power wire through the firewall. Has anyone out there done this before on an '01-'04? What is the easiest route?
netboy
Copper - Posts: 108
Posted: March 11, 2004 at 2:33 AM / IP Logged
automatic or manual? if automatic just run through the clutch hole
Memphis MC-1300
2 12" JLw6v2
Diamond audio M3 6x9
Diamond audio M3 5.25 components
Audio control Matrix
Carputer
nigelio
Posted: March 11, 2004 at 2:36 AM / IP Logged
its a manual. Through the clutch hole? then where? under the console and the rear carpet and back seat?
netboy
Copper - Posts: 108
Posted: March 11, 2004 at 4:07 AM / IP Logged
Hmmm...in my old nissan i drilled a hole into the front passenger floorboard then put some rubber gorments so water wouldn't get it.  It worked for me, but i am by no means a professional.  Hopefully some of the other guys could help.
Memphis MC-1300
2 12" JLw6v2
Carputer
DvMxDv
Member - Posts: 8
Posted: March 17, 2004 at 12:49 PM / IP Logged
Nigelio,
Here's a link to install instructions for Honda factory foglights from H and A Accessories.  If your car doesn't have foglights installed, you can use the route for your amp power instead.  The location is on page 6 of the pdf.
http://www.handa-accessories.com/civic/04-civfogex.pdf
Hope this helps.
Dave
jugga-nemo
Copper - Posts: 81
Posted: March 17, 2004 at 12:57 PM / IP Logged
If that doesn't work, just drill a hole in the firewall and use a grommet to plug it up.  Just make sure that there is nothing on the otherside that you could accidentally drill through.
5.25" Components & 5x7 Coax Kappas w/Power Acoustik OV4-800
KAC 7252 powering 2 D3 8" Diamonds
KDC-MP728, KGC-4042A
Monday, April 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
