Dool Lock Actuator
boost
Posted: March 11, 2004 at 1:07 PM / IP Logged
I am about to install a start/alarm into a 92 Subaru Legacy 4 door, and notice on the schematic that it says I need to put an actuator in the door....This car has the powerlocks on it where you lock the driver door and the other doors follow suit....
Isn't there a way to tap the wires or is it pretty much mandatory to go with the actuator?
bmf1000d
Silver - Posts: 345
Posted: March 11, 2004 at 1:13 PM / IP Logged
No because they use what the hyundai have its called remote door locking you have to add and actuator the the driver door only that in turn will lock all the other doors.
"Big" Mike
Double Take
Fremont, Ne
remember to check all your wires with a dmm not a test light!!
i take no responsibilty whatsoever for the vailidty of the info nor consequences thereof
boost
Posted: March 11, 2004 at 4:30 PM / IP Logged
Ok cool, just figured there was a way around it.  Guess I will be pulling the door panel :)
monzie32
Member - Posts: 6
Posted: March 13, 2004 at 5:08 PM / IP Logged
ive done this years ago trying to remember-if it has keyless already- ther is wires in kick that you can hook up-forget the colors-if no keyless you need motor
boost
Posted: March 13, 2004 at 6:53 PM / IP Logged
No keyless, just the powerlock when you lock the driver door :(
