clifford matrix 3 on plymouth neon doors
pelochas
Posted: March 13, 2004 at 10:48 AM / IP Logged
i got the alarm installed on my 2000 plymouth neon with automatic door locks and it will arm and disarm. i cant figure out the door locks to lock and unlock when arming and disarming. can someone please help me with this.
the manual for the alarm is under the clifford column and its a matrix 3 alarm http://www.directed.com/guides/igs.asp
there is a 8 pin H2 relay harness that im also confused. is this for the doors or other aux options. please help thanks
kgerry
Platinum - Posts: 3,455
Posted: March 13, 2004 at 11:00 AM / IP Logged
keyless is done though a light green wire with relays and resistors, the resistor value changes depending on whether your car has factory keyless or not, also requires a double pulse on unlock...
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
