honda cd changer?
gooeey
Member - Posts: 6
Posted: August 16, 2002 at 5:44 PM / IP Logged
HEY I GOT A 96 HONDA ACCORD.THE STOCK RADIO HAS CD CHANGER CONTROLS ON IT,ALSO I HAVE A  ALPINE  CHA 1214 12 DISC CHANGER JUST SITTING IN MY GARAGE.DOES ANYBODY KNOW IF THESE ARE COMPATIBLE?
sal c.
Sound Pressure
Silver - Posts: 711
Posted: August 16, 2002 at 11:30 PM / IP Logged
You will need a periphial I know that is not spelled right but it sure does sound right. Your local car audio shop should carry these.
Sound Pressure
omega
Copper - Posts: 54
Posted: August 17, 2002 at 2:11 PM / IP Logged
As far as I know they are not compatible.  The "A" in CHA-1214 indicates that the changer is an Alpine AI-NET changer.  The changers that are compatible with the Honda factory units are the lower cost, M-BUS Alpine changers designated as CHM-XXXX.
So unless you sell that Alpine and get an M-BUS model you can't use it without an Alpine HU (with AI-NET control).
CORRECTION:  It isn't that ALL AI-NET changers won't work but the 1214 won't.  There are SOME Alpine AI-NET changers that are "dual-bus" capable which are usually denoted with an "S" such as "CHA-SXXX" in the model number.  However even these require 2 separate adapters...  One is the Honda to M-Bus adapter and the other is the Alpine KCA-130B AI-NET to M-BUS adapter (which ONLY works on dual bus capable models, which the 1214 is not.)
