2003 dodge caravan
jay's detailing
Member - Posts: 24
Posted: March 15, 2004 at 6:54 AM / IP Logged
If anyone out there has wiring diagram for a 2003 or 2004 dodge caravan and can e-mail me copy to c**key420@yahoo.com you will be my best buddy... thank you
              angel..
bmf1000d
Silver - Posts: 345
Posted: March 15, 2004 at 10:34 AM / IP Logged
here ya go for the diagram
Dodge
Caravan
2002-2003
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
YELLOW (NOTES BELOW)
IGNITION SWITCH HARNESS**
Ignition  #1:
PINK/WHITE
Ignition #2:
N/A
Ignition  #3:
N/A
Accessory:
N/A
Brake  Light:
WHITE/ TAN
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
PURPLE / ORANGE (AC)
GRAY CONNECTOR BY IGNITION MODULE
Parking Lights:
WHITE/ BROWN (-)
AT HEADLIGHT SWITCH***
Headlights:
OEM Alarm  Disarm:
VIOLET/LT. BLUE
AT PLUG AT PCM ON FIREWALL DRIVER'S SIDE******
OEM Alarm  Arm:
VIOLET/LT. BLUE
Diesel  Glow Plug:
N/A
Clutch  Bypass Wire:
N/A
Notes:
 * Many Of These Vehicles Are Equipped With A Transponder (Even If The Key Is Black). Use Universal Alarm Bypass Module Part Numner 2x402 Where X Can Be Any Number. ** NOTE!!! A Second Start Wire (PURPLE / Brown) Needs a relay installed to provide a ground (-) through a 180 Ohm Resistor during crank in order to remote start the vehicle, See Installation Note #162. ***The parking lights are negative trigger through a 2.1K ohm resistor. ****All DesignTech remote starters except the 2xx22 have an ignition 3 output - it is the WHITE/ black in the 'control harness'. This wire will be used to control the bypass module, if needed.
Dodge
Caravan
2002-2003
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
RED
IGNITION SWITCH HARNESS (MAX # AMPS)
Starter  Kill:
Ignition  +12 Volts:
PINK/WHITE
Dome  Lights/Superv:
BLACK/ WHITE (-)
AT 4 PIN PLUG NEAR FUSE PANEL
OEM Horn:
GREEN/ BLACK (-)
STEERING COLUMN HARNESS
Power  Lock:
PURPLE / GREEN
AT PLUG AT PCM ON FIREWALL *****
Power  Unlock:
PURPLE / GREEN
Trunk  Release:
VIOLET/TAN
AT PLUG AT PCM ON FIREWALL DRIVER'S SIDE ******
Alarm  Input Wire:
BLACK/ WHITE (-)
Notes:
*****for the 2001-02 Caravan Lock is negative trigger through a 5.3k ohm resistor. Unlock is negative trigger through a 2.0k ohm resistor. For the 2003 Caravan Lock is negative trigger through a 2.2k ohm resistor. Unlock is negative trigger through a 390 ohm resistor. The Body Control Module (BCM) is in the driver kick panel near the the parking brake, ******See Installation Note #211. A Single Pulse Of Ground Through A 2.2 K-Ohm Resistor Will Open The Liftgate. POWER SLIDING DOORS: Violet/Dk. Blue Wire At Switch. Driver's Side - A Single Pulse Of Ground Through A 2.7 K-Ohm Resistor. Passenger's Side - A Single Pulse Of Ground Through A 1.5 K-Ohm Resistor. ****** To disarm the OEM alarm a negative trigger through a 9.20k ohm resistor.
"Big" Mike
Double Take
Fremont, Ne
remember to check all your wires with a dmm not a test light!!
i take no responsibilty whatsoever for the vailidty of the info nor consequences thereof
