Capacitor Voltage Ratings
bradleonard
Copper - Posts: 94
Posted: March 15, 2004 at 10:13 PM / IP Logged
I am trying setup one of these circuits shown in the special applications relay section of the board.
https://www.the12volt.com/relays/page5.asp#pts
I set this circuit up just as shown with the exception of the capacitor. I did have nor could I get a 10k uf capacitor. The guy at the supply house where I got the rest of the parts said that 10k uf was not a way of noting the value of the capacitor. Anyways, I used a 220 uf 16volt Capacitor in my setup. When I applied power to the input of the circuit the relay did not stay closed for ANY amount of time, at least not any length of time detectable by the human ear (via the tone of my fluke meter). Does my problem lie in the Capacitor I am using? How long of a hold should I get off of the given capacitor rating in this diagram?
I have been looking for a capacitor of a 10k uf rating in the radio shack catalog. They only carry capacitors rated at 35 and 50 volts in the store, but they do offer RSU special orders for Capacitors that are rated at 16 volts. Does the voltage rating matter when using them in a 12 volt situation? If so, is 16 volt the rating to use? Once again, the highest value of (Electrolytic) Capacitor that is in the radio shack catalog is 4700 uf at any voltage. ATTENTION MODERATORS! Maybe its time for a basics page on Capacitors!!
lastly, are resistors directional? Or do they work no matter which direction they are inserted in the circuit?
werd
atwageman
Member - Posts: 43
Posted: March 16, 2004 at 3:12 AM / IP Logged
First things first.  Resistors are NOT directional.  As far as capacitor voltages are concerned, it is ok to use 35 volt or 50 volt capacitors in automotive applications.  And remember electrolytic type capacitors are directional, they have a positive and a negative.  There are non-polarized electrolytics out there, but are more commonly seen in crossover set-ups, etc.
Avoid special ordering parts thru radio shack.  They are too expensive!  I use Digi-Key, All Electronics, Parts Express, and a host of others.
Al Capone's business card said he was a used furniture dealer.
bradleonard
Copper - Posts: 94
Posted: March 16, 2004 at 4:31 AM / IP Logged
That partially answered my questions. I figured that Resistors were non-directional but had no way of knowing for sure.
In regards to Capacitor voltages, by using higher voltages that does not change uf value?
So any ideas as to why the circuit I mentioned didn't stayed closed for any amount of time?
Does a 10k uf cap. exist?
werd
atwageman
Member - Posts: 43
Posted: March 16, 2004 at 5:24 AM / IP Logged
Voltage will not change the uf.  The cap you are needing is actually 10,000uf.  It is a common value, but you will have to order it from a electronics parts supplier like I mentioned above.  The capacitor you are using is only 220uf.
atwageman
Member - Posts: 43
Posted: March 16, 2004 at 5:25 AM / IP Logged
The k means thousand.   10kuf is 10,000uf.
bradleonard
Copper - Posts: 94
Posted: March 16, 2004 at 6:00 PM / IP Logged
So is there a formula that would give me a rough idea of how long a given capacitance rating will hold a relay coil?
This diagram https://www.the12volt.com/relays/page5.asp#ctm seems to say that a 1000 uf (1k uf) will hold a relay coil for 1/2 a second. Can I assume from this that a 10,000 uf (10k uf) cap. will hold a relay for 5 seconds?
Thanks in advance
werd
bradleonard
Copper - Posts: 94
Posted: March 20, 2004 at 2:51 AM / IP Logged
CAN ANYONE ANSWER THE PREVIOUS QUESTION?
werd
its_radio_shop
Copper - Posts: 76
Posted: March 20, 2004 at 9:46 PM / IP Logged
If it were me I would just solder or hold the larger cap in and time it, changing values until I got the exact time I was looking for. Am sure you could use a formula to figure it out but I assume you dont have a way to measure the inductance of your relay coil to plug into the formula either, not to mention just experimenting will probably be easier/faster.
Toru
Copper - Posts: 102
Posted: March 21, 2004 at 12:09 AM / IP Logged
Sorry bradleonard, but I don't think you'll get an answer on the cap values from this forum. I ran into the same "blank stare" when I was researching the CTM relay setup.
From my experience the 10,000uf will work out to 5 seconds. In my application I used a 470 uf to reduce the relay time to ~1/4 second.
One thing to watch out for is that the circuit is not "ready to go" again until the cap drains. For the 1000uf circuit, that is 10 seconds, for the 470uf, about 5 seconds. What that means is when you trip the CTM, you will not be able to trip it again until the cap discharges. An attempt to trip it before that timeout will reset the timeout.
In my case, I am reducing a 1 second 3rd channel out down to 1/4 second for trunk release. Once I pop the trunk, I cannot pop it again until I wait 5 seconds. If I hold the remote button down before that I will reset the discharge time and have to wait another five seconds from that point. I.e. if I press the button every four seconds for an hour the trunk will never pop in that hour (after the first pop).
Also, I am using the auto-unlock-on-ignition-off relay setup. That one is using a 1000uf cap for a 1/2 second unlock pulse. If I turn on the ignition on and then off BEFORE 10 seconds have elapsed, the unlock will NOT trigger.
I am not actually incovenienced by this (how fast do I need to pop my trunk multiple times in a row, and how many trips in the car are less than 10 seconds? :-) but you should be aware of this as your timeout will be one minute forty seconds I reckon.
bradleonard
Copper - Posts: 94
Posted: March 21, 2004 at 2:36 AM / IP Logged
Thanks Toru
I get the feeling that pretty much no one even understands capacitors on this board much less has any practical experience with them. I come to this conclusion after reading through all the posts on large caps used for amps and the confusing myths that float around about those. The 10,000uf cap. that is specified in the diagram I originally sited in this thread reinforces my thoughts about the knowledge of caps. A cap of that size in the micro farad range is not readily available unless you want to try to order one from one of the large suppliers and even then you have wade through pages and pages of parts to find the right one. I am going to try a 4700uf cap. and see what that does for me. I don't need a fast recovery rate for this circuit, in fact it doesn't need to recover until the next time I start my truck, but I do want it to latch the relay for at least a second or two. Which be long enough for me to push the button and then reach over and put the key in the ignition and turn it. I will let you know it goes.
THanks
werd
Friday, December 19, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
