97 f150 pwr door locks
Amangill
Member - Posts: 13
Posted: March 16, 2004 at 2:17 AM / IP Logged
hi i also can find the pwr door lock wires on the 97 f150 if anyone knows there location please help thanks
aman
draasch
Gold - Posts: 2,172
Posted: March 16, 2004 at 6:12 AM / IP Logged
Make:   Ford
Model: Pickup - Fullsize
Year:    1997
This Database Was Last Updated On:    6/9/2003
Index #: 9045
Alarm
Constant 12 volts YELLOW (2), ORG/YEL & L GREEN/ PURPLE (2) IGN. SW. HARNESS
Ignition 12 volts D BLUE/GREEN IGNITION SWITCH HARNESS
Starter RED / L BLUE IGNITION SWITCH HARNESS
Dome Light BLACK/ L BLUE (+) PASSENGER KICK PANEL
Trunk Pin Switch N/A
Parking Lamp BROWN (+) AT HEADLIGHT SWITCH
Power Lock PINK / YELLOW DRIVER KICK * #203
Power Unlock PINK/L GREEN PANEL #201
* Without OEM Keyless Entry See Note #203, With OEM Keyless Entry See Note #201. #203- See Reversal Rest At Ground Door Lock Diagram. #201- See Negative Pulse Door Lock Diagram.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
