1999 Grand AM Passlock II
mbiker1
Member - Posts: 37
Posted: March 19, 2004 at 11:51 AM / IP Logged
How do you bypass the GM's Passlock II Anti-Theft System. Is there a way by making a jumper or do i have to buy a module for it?
draasch
Gold - Posts: 2,172
Posted: March 19, 2004 at 2:43 PM / IP Logged
you will need a passII or a DB-PLDATA
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
kgerry
Platinum - Posts: 3,455
Posted: March 19, 2004 at 4:18 PM / IP Logged
or a 555L from DEI
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
golfnut64
Copper - Posts: 80
Posted: March 20, 2004 at 8:29 AM / IP Logged
HI You can also make a bypass with a resister of the correct value placed between the engine side of the yellow wire & the ORANGE / black passlock wires, if you want i can send a diagram if i get an e mail adderess ,or you can go to design tech web site
Platinum - Posts: 12,488
Posted: March 20, 2004 at 9:18 AM / IP Logged
http://www.velocitymotorsport.com/install_notes/Chevy.htm
Go to the bottom of the first column for the bypass relay diagram & instructions.
Thursday, March 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
