Please help w/ Miata Dome Light
lllike
Posted: March 20, 2004 at 3:05 PM / IP Logged
Hello everyone,
I'm new to this website, I was surfing the web for information on hooking up the Dome Light Supervision to a DEI Viper 300 ESP and found this :)
The instructions from DEI says that the dome light supervision wire is a -200ma output from the alarm.  What I want to do is to make it activate a Miata light kit that is installed in the center counsel part of the car as opposed to the dome light, or along with the dome light.  Can anyone help?
Is the -200ma trigger strong enough to switch a regular automotive 30A relay?
Thanks in advance for any input.  I know DEI sells a relay #DEI 8616 but was wondering if I could just use a regular automotive relay.  Circuit City quoted me $30 bucks for the relay.
kgerry
Platinum - Posts: 3,455
Posted: March 20, 2004 at 3:11 PM / IP Logged
yep, just a standard Bosch or P&B relay will do what you want it to..... the domelight out put of that unit is designed to trip a relay
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
lllike
Posted: March 20, 2004 at 3:16 PM / IP Logged
thanks... I've tried to use the alarm wire to trip a relay, but I couldn't get it to work...  can you tell me how to hook it up? I've tried a bunch of combinations from this site as well as the instruction book.
alarm (blk/wht) wire - 85  12v constant - 86   Ground - 87   Output -30
the output on the alarm trigger is only about .6 volts
kgerry
Posted: March 20, 2004 at 3:32 PM / IP Logged
which "alarm" wire?? the domelight supervision wire?
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
draasch
Gold - Posts: 2,172
Posted: March 20, 2004 at 6:15 PM / IP Logged
are you trying to get that light to flash with the parking lights or do you have a separate for the dome light feature?
86 12v fused
85 ground from alarm
87 - or + which ever is needed for the light
30 to wire for light
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
lllike2
Posted: March 22, 2004 at 12:44 AM / IP Logged
Hello All,
Yes, I am attempting to use the alarm dome supervision wire (WHITE/ black) to trigger a replay to light a light bulb (not the dome light).  I've tried the combinations listed above but it has not work.  Am I missing something?
The instruction book says it gives out a (-200ma) signal, but when I use a volt meter, it puts out a positive 0.6 volt reading.  Am I suppose to hook up the external lights ground lead to the relay?  This negative signal stuff got me bugged, I can't seem to picture it or make it work
Thanks again for your help and advice.
Should it be something like this?
86 12v fused
87 - or + which ever is needed for the light  (ground)
30 to wire for light (ground ---- light bulb---- 12v fused)
lllike3
Posted: March 22, 2004 at 6:42 PM / IP Logged
Hello Everyone,
I've been trying to reply to this post, but I can't seem to log in, so I just created new screen names.  Does anyone know why this might be happening?
Thanks for the help again...
Mike
