Alpine 8048 install manual
mike5133
Posted: August 18, 2002 at 1:03 PM / IP Logged
I'm looking for an install manual for an Alpine 8048 alarm.  I have the wiring diagram for the alarm but would like to see a install manual if there is one.
If anyone has any experience installing this alarm in a 95 Toyota Camry, I'd take any pointers!
dfiddy
Copper - Posts: 162
Posted: August 18, 2002 at 5:00 PM / IP Logged
if it helps any, which i don't think it will, i have the manual for the 8028. I dont know how similar they are but this is a message board that is supposed to help people out and that's what i am trying to do :)
keep it real...
Platinum - Posts: 12,488
Posted: August 19, 2002 at 5:18 AM / IP Logged
Hey   mike5133......... What do you need to know about the installation ?? The wiring diagram is all you need for the alarm. Here's the wiring diagram for the vehicle:
|              12V|white - WHITE/ red   |+  |ignition harness            |
|          STARTER|BLACK/ white         |+  |ignition harness            |
|         IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|  SECOND IGNITION|BLACK/ orange        |+  |ignition harness            |
|        ACCESSORY|pink/blue *1        |+  |ignition harness            |
|       POWER LOCK|blue/white          |-  |passengers kick             |
|     POWER UNLOCK|lt. GREEN/ red       |-  |in a blue plug              |
| PARKING LIGHTS +|green               |   |bottom of fuse box *3       |
| PARKING LIGHTS -|green               |   |steering column             |
|       HEADLIGHTS|RED / yellow          |-  |steering column             |
|     DOOR TRIGGER|RED / white           |-  |*4                          |
|  TRUNK/HATCH PIN|RED / white *5        |-  |light or sw. in trunk       |
|         HOOD PIN|                    |   |                            |
|TRNK/HTCH RELEASE|                    |   |                            |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|                    |   |                            |
|       TACHOMETER|black               |   |*2                          |
|       BRAKE WIRE|GREEN / WHITE         |+  |bottom of fuse box *3       |
|     HORN TRIGGER|GREEN/ black         |-  |steering column             |
|           WIPERS|                    |   |                            |
|  LF WINDOW UP/DN|green - red         |A  |drivers door switch         |
|  RF WINDOW UP/DN|grn/wht - RED / blu   |A  |drivers kick panel          |
|  LR WINDOW UP/DN|grn/yel - RED / yel   |A  |drivers kick panel          |
|  RR WINDOW UP/DN|grn/blk - RED / blk   |A  |drivers kick panel          |
Notes:
*1 Not required for remote start.  *2 On the 4 cylinder motor the black wire is at the check connector located on the rear side of the passenger strut tower.  On the 6 cylinder the black wire is at the ignitor located on the drivers side strut tower.  *3 In a white connector just below the fuses with the wires exiting out toward you.    *4 Remove black plastic air duct covering the top right side of the fuse box to access a 6 pin plug containing the RED / white.   *5 Tied in with the door trigger on the wagon models.
mike5133
Posted: August 19, 2002 at 8:37 AM / IP Logged
dfiddy thanks for the offer but I don't think it will help.
Velocity Motors thanks for the info.  It gives me more detailed info than I had already.
