2002 Grand Am remote start
mrnix
Member - Posts: 19
Posted: August 18, 2002 at 2:23 PM / IP Logged
Do I need to do anything  special to get around the anti-theft system to remoote start this car?  It's been a while since I've done a GM.  I've bypassed the VATS system, but I think they have a new system now.  Thanks for any assistance.
Will
mrnix@hotmail.com
beegbie
Copper - Posts: 341
Posted: August 18, 2002 at 3:52 PM / IP Logged
The Grand Am has passlock II. There are many companies that make overrides for this but you can still do it with 2 relays. Wire the first relay like the vats setup. The colors are yellow and ORANGE / black at the key cylinder.(you must cut the yellow) Then wire the second relay to hold the first one on until the ignition is turned off. This must be done because the cylinder does not provide the signal until the key is turned to the crank position.
Platinum - Posts: 12,488
Posted: August 19, 2002 at 5:19 AM / IP Logged
https://www.the12volt.com/downloads/file.asp?ID=250
Go to the link above for bypass method without purchasing the bypass module.
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
