2001 Dodge Grand Caravan
Welcome Guest :)
mrjazz
Member -
Posted: March 23, 2004 at 5:21 PM / IP Logged
Hi all does anyone have the wiring diagram for a 2001 Dodge Grand Caravan Sport.
boomer_106
Silver -
Posted: March 23, 2004 at 8:22 PM / IP Logged
Remote Starter Wiring Colors and Notes |
Function | | Vehicle Color | Location |
Start: | | YELLOW | IGNITION SWITCH HARNESS |
Ignition #1: | | PINK/WHITE | IGNITION SWITCH HARNESS* |
Ignition #2: | | N/A | |
Ignition #3: | | N/A | |
Accessory: | | N/A | |
Brake Light: | | WHITE/ BLACK | AT SWITCH ABOVE BRAKE PEDAL |
Tach Signal: | | | |
Parking Lights: | | WHITE/ BROWN (-) | AT HEADLIGHT SWITCH** |
Headlights: | | | |
OEM Alarm Disarm: | | VIOLET/LT. BLUE | AT PLUG AT PCM ON FIREWALL DRIVER'S SIDE *** |
OEM Alarm Arm: | | VIOLET/LT. BLUE | AT PLUG AT PCM ON FIREWALL DRIVER'S SIDE *** |
Diesel Glow Plug: | | N/A | |
Clutch Bypass Wire: | | N/A | |
Notes: | | * This Vehicle May Be Equipped With A Transponder Theft System That Can Be Identified By A Gray Ignition Key. Use Universal Alarm Bypass Module part # 2x402 where X can be any number. ** The parking lights are negative trigger through a 2.1k (2100) ohm resistor. *** Disarm is negative trigger through a 9.1k (9100) ohm resistor. Arm is negative through a 1.5k (1500) ohm resistor. ATTENTION- Some of these vehicles fall under a campaign program though the manufacturer to upgrade the computer system when the vehicle is serviced at the dealer. After the upgrade is complete the vehicle may not remote start. The solution is to add the second start wire as per the 2002+ Chrysler Mini-Vans. Unfortunately, feedback from installers indicates it is not possible to add the second start wire prior to the computer upgrade procedure as unexpected vehicle behavior may result. If the upgrade has been performed connection of the second start wire is required. See Note #162 |
Alarm and Keyless Entry Wiring Colors and Notes |
Constant +12 Volts: | | RED | IGNITION SWITCH HARNESS (MAX # AMPS) |
Starter Kill: | | YELLOW | IGNITION SWITCH HARNESS |
Ignition +12 Volts: | | PINK/WHITE | IGNITION SWITCH HARNESS* |
Dome Lights/Superv: | | BLACK/ WHITE (-) | AT 4 PIN PLUG NEAR FUSE PANEL |
OEM Horn: | | GREEN/ BLACK (-) | STEERING COLUMN HARNESS |
Power Lock: | | PURPLE / GREEN | AT PLUG AT PCM ON FIREWALL **** |
Power Unlock: | | PURPLE / GREEN | AT PLUG AT PCM ON FIREWALL **** |
Trunk Release: | | VIOLET/TAN | AT PLUG AT PCM ON FIREWALL DRIVER'S SIDE |
Alarm Input Wire: | | BLACK/ WHITE (-) | AT 4 PIN PLUG NEAR FUSE PANEL |
Notes: | | **** See Installation Note #211. Lock is negative through a 2.2k (2200) ohm resistor. Unlock is negative through a 5.3k (5300) ohm resistor. |
Tuesday, April 7, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
