2004 Ford F-250 Diesel Alarm/Remote Start Wiring
ringwood
Member - Posts: 13
Posted: March 25, 2004 at 7:36 AM / IP Logged
Hi
Where can I get  wiring diagrams for a 2004 Ford F250 diesel?
Thanks,
Sid
jfk51502003
Copper - Posts: 221
Posted: April 01, 2004 at 1:41 PM / IP Logged
12voltsyellow & lt. GREEN/ purple + ignition harness
Startergreen + ignition harness
Second StarterN/A
IgnitionRED / lt. green or WHITE/ yellow + ignition harness
Second IgnitionN/A
Third IgnitionN/A
Accessorygray / YELLOW & RED / black + ignition harness
Second Accessoryblue/lt. green + ignition harness
Keysense
Power Locksee notes
Notes: Without keyless entry use pink / YELLOW for lock and pink/lt. green for unlock. They are 5 wire reverse polarity mastered from the driver switch and found in either kick panel. With keyless entry use WHITE/ red for lock and BLACK/ white for unlock. They are negative trigger and found at the VSM.
On the vehicles with keyless entry the GEM shuts down after the doors have been locked for a certain time period, to wake up the system refer to DirectFax document 1094.
Power Unlocksee power lock notes
Lock Motorpink/black 5wiVSM
Notes: The VSM (Vehicle Security Module) is to the right of the accelerator pedal above the transmission hump below the radio. Not accessible from radio opening.
Unlock MotorRED / orange 5wiVSM
Parking Lights+brown + headlight switch
Parking Lights-N/A
Hazardssame as turn signals
Turn Signal(L)lt grn/wht (F), lt grn/org (R) + steering column
Turn Signal(R)wht/lt blu (F), org/lt blu (R) + steering column
Reverse LightBLACK/ pink + fuse box
Door TriggerBLACK/ lt. blue + either kick panel
Dome Supervisionuse door trigger
Trunk/Hatch PinN/A
Hood PinN/A
Trunk/Hatch ReleaseN/A
Power Sliding DoorN/A
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
TachometerNOT RED / lt. green ac any ignition coil
Notes: On diesel vehicles the tach wire is GREEN / WHITE in a 5 wire harness held up with white tape behind the parking brake release.
Wait to startsee DirectFax document 1091
Brake Wirelt. green + brake pedal switch
Parking Brakelt. GREEN/ red - parking brake switch
Horn Triggerblue - steering column or VSM
Memory Seat 1BROWN / lt. green - memory mod under dr seat
Memory Seat 2BLACK/ orange - memory mod under dr seat
Memory Seat 3N/A -
2004 Ford F-250 Diesel Alarm/Remote Start Wiring -- posted image.
Immobilizer Bypass Module:Required: NoType: N/APart #: N/A
Notes: N/A
Sunday, August 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
