2003 Ford F250 Remote Start
Ockander
Posted: March 27, 2004 at 6:06 PM / IP Logged
 HI Im having trouble installing my remote start. The alarm is telling me its indicating a neutral saftey shut off. Does anyone know how to remedy this? Im confused if the alarm is supposed to detect a ground or a 12v+ . Any help would be really REALLY appreciated!!
Thanks, Jeremy
Ockander
draasch
Gold - Posts: 2,172
Posted: March 27, 2004 at 8:29 PM / IP Logged
well first tell us what brand of remote start u have....
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Ockander
Posted: March 27, 2004 at 8:36 PM / IP Logged
I've got a Hornet 554T alarm with remote start. Im banging my head against the wall on this problem!! The diagnostic test keeps coming back that I've got a neutral safety shutdown. I've tried grounding the lead.. That doesnt seem to work. I cant seem to find a neutral safety input wire coming from the ignition block. Acutally Im not even sure what Im supposed to look for to find that lead. Do you know if its a 12v- lead or something? Or even do you know how to bypass it entirely!
Thanks for responding. I apprecaite it!
Jeremy
Ockander
draasch
Gold - Posts: 2,172
Posted: March 27, 2004 at 9:48 PM / IP Logged
here is all i have on that truck...Neutral Safety NOT GROUNDING TYPE - OEM SWITCH OPENS STARTER CIRCUIT....i would think you can some how bypass it...depends on what that wire need to see as far as polarity.
Good Luck
David
Ace Security
813-376-9778
Tampa
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
