need help with the lock/unlock
Firemedic8233
Posted: March 30, 2004 at 8:43 PM / IP Logged
i have a 1997 silverado and cannot figure out with wire on the door switch is the lock or unlock.  i have a performance teknique 2-way alarm with the internal relays.  i have 4 wires for the door locks and two are for either constant + or - and the other 2 are for lock and unlock.  can anyone help me pls?
thanks,
robert
boomer_106
Silver - Posts: 710
Posted: March 30, 2004 at 10:27 PM / IP Logged
Here is a diagram for the truck. It tells you the location to interface the door lock wires. If you need anymore help just post back. Good luck
Chevrolet
Pickup - Fullsize
1996-1998
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
YELLOW
IGNITION SWITCH HARNESS *
Ignition  #1:
PINK
Ignition #2:
PNK/WHT or WHT
IGNITION SWITCH HARNESS(ECM)
Ignition  #3:
N/A
Accessory:
ORANGE
IGNITION SWITCH HARNESS (HEAT/AC)
Brake  Light:
WHITE (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
WHITE
AT COIL ON PASSENGER REAR OF ENGINE
Parking Lights:
BROWN (+)
AT HEADLIGHT SWITCH
Headlights:
YELLOW (+)
AT HEALIGHT SWITCH
OEM Alarm  Disarm:
N/A
IN SCHEMATICS
OEM Alarm  Arm:
N/A
NO OEM ALARM PRESENT
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * 1998 Vehicles Are Equipped With GM's PASSLOCK II Anti-Theft System; See Note #113.
Chevrolet
Pickup - Fullsize
1996-1998
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
RED (2)
Starter  Kill:
YELLOW
Ignition  +12 Volts:
PINK
Dome  Lights/Superv:
PURPLE (-)
4 PIN BLACK CONN. IN DR. KICK PANEL **
OEM Horn:
BLACK (-)
STEERING COLUMN HARNESS
Power  Lock:
L BLUE
DRIVER'S KICK PANEL IN BODY CAVITY ***
Power  Unlock:
WHITE
Trunk  Release:
N/A
Alarm  Input Wire:
PURPLE (-)
Notes:
** PURPLE (-) Wire Also Located At Headlight Switch. WHITE (-) Wire At Courtesy Light Can Also Be Used But Will Not Trigger Alarm If Dome Lamp Override Switch Is Turned On. *** Without OEM Keyless See Note #203 - Reverse Polarity Door Lock Diagram. With OEM Keyless See Note #202 - Positive Pulse Door Lock Diagram.
