ram infinity help
04hemi
Posted: April 02, 2004 at 11:24 PM / IP Logged
Is there a way to install a aftermarket head unit (kenwood 715dvd) without bypassing the factory amp.  The amp is buried in the dash somewhere and I can't figure out how to find it.  I did a search but there is no light green wire in my factory harness.  The stock radio itself has 2 plugs but my truck only has one harness going to the radio
mobile1
Silver - Posts: 479
Posted: April 03, 2004 at 12:40 AM / IP Logged
the fact. amp is behind the glove box. you can pull the glove box out and access it from there. That is the only way I would do it. You COULD hook up the amp turn on wire (blue wire from aftermarket harness, usually blue on aftermarket HU). That sometimes will integrate the fact amp into the system. I have seen this fry out the fact amp and blow many speakers in the past, so be careful.
mobile1
Silver - Posts: 479
Posted: April 03, 2004 at 12:42 AM / IP Logged
if there is no lt. green wire in the harness, is there a fact. amp? If it says infinity on the radio or speaker grills you do, if not you probably don't.
04hemi
Posted: April 03, 2004 at 1:18 AM / IP Logged
it is dark green.  I just wish there was a easier way to get  to the factory amp
mobile1
Silver - Posts: 479
Posted: April 03, 2004 at 1:23 AM / IP Logged
its definatly not a fun one. you can try going from underneath the glove box, under the dash or removing the box completely
