Horn Relay?
carguy411
Silver - Posts: 683
Posted: August 21, 2002 at 12:05 PM / IP Logged
i am going to put an alarm/remote startin in a infinity g20. now the customer already has an airhorn replacing the factory horn. there is a relay under the hood already powering the air horn. now when i wire in the horn ouput of the alrm do i need to add a relay even though there is one undser the hood alraedy. can i just go right out aff the alarm to the horn wire.
if i need a relay can i just hook the horn output to the relay under the hood
please let me know
thanks
1nicemustang
Copper - Posts: 89
Posted: August 21, 2002 at 12:31 PM / IP Logged
to be safe id attach the wire before the horn relay. are the air horns running off that relay also?? if so the compressor might be a bit much with both going at once.
Lee
carguy411
Silver - Posts: 683
Posted: August 21, 2002 at 1:01 PM / IP Logged
there is a new installed realy under the hood for the air horn. so should i install another realy off the alarm or just run the horn output straite to the horn wire in the car
thanks
sparkyssb
Copper - Posts: 205
Posted: August 21, 2002 at 1:40 PM / IP Logged
well, if he's got the air horn to work with his standard horn switch (in the steering wheel), then just hook it up like a normal horn, straight off the horn wire. The relay is there so that after the (-) is given by the horn switch, it turns on the relay thus powering the air horn through pins 30 and 87.
just, everytime his alarm goes off , watch out!!! its gonna be loud! Horn Relay? -- posted image.
sparkyssb
Copper - Posts: 205
Posted: August 21, 2002 at 1:41 PM / IP Logged
P.S. If your wondering where to wire it up at, make sure its before the relay, not after.
Monday, July 21, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
